is timing really this hard
Old Dec 17, 2003 | 08:56 AM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
i have had timing issues with my car for a while now back about 2 months i posted a question on this board and someone told me that base timing is 7 advanced well the car ran decient but the vacum was real low around 12 kpa so today i decided to adjust my timing to 0 because thats what the catalyst sticker says i accidently advanced it some more and it is extremely hard to get it to start can someone please tell me the proper procedure for adjusting timing on a 92 rs 305 tbi
Old Dec 17, 2003 | 09:04 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
like any other SBC, hook up your timing light, let the car idle, turn the distributor until the the timing mark is at the point where you want it.
Old Dec 17, 2003 | 10:19 AM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
what about the magnetic timing probe socket and where is the timing set when the car comes from the factory which way is advance and which was is retard
Old Dec 17, 2003 | 10:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
magnetic timing probe socket ?????
the timing on TBI cars is set to 0* from the factory, to tell you the truth, sitting here at work, which way you turn the dizzy is escaping my mind, i want to say clockwise will retard, counter-clockwise will advance. but my mind isn't working that well right now.
Old Dec 17, 2003 | 10:38 AM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
yea the magnetic timing probe socket if you read the manual or a chiltons the is a special tool your suppost to use if you look down at the damper and you see the marks that are used to set the timing there is a slot for it to go in but i dont know if it is really neccessary
Old Dec 17, 2003 | 10:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i have never heard of that. what year are you looking at?
just use your timing light, and you will see the timing mark. nothing more too it, other than disconecting the ESC.
Old Dec 17, 2003 | 10:52 AM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
its a 92 ill try just setting it to 2 advanced but hopefully someone else will reply and tell me which way to turn the distributor thanks
Old Dec 17, 2003 | 10:55 AM
Dewey316's Avatar
Car: 1990 Camaro RS
and remeber to unplug the ESC, if you time it with that plugged in, you will be running like 18-20* RETARDED.
Old Dec 17, 2003 | 11:17 AM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
do i unplug it before i start the car?
Old Dec 17, 2003 | 12:12 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
dewey is right, counterclockwise=advance, clockwise=retard. i dont think it matters if the car is running or not when you unplug the esc. ive done it while the car is running and when it is not. as far as that hole for the probe, ignore it, it means nothing to you. or anyone else for that matter
Old Dec 17, 2003 | 06:00 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
To set timing hook up your timing light with the magnetic pickup on the #1 spark plug wire, start the car and let the idle smooth itself out (it's easier to start the car with the ESC connected, but it doesn't really matter). Disconnect the ESC and hop on the radiator support and fire away. From the top, CCW is advance and CW is retard. Reconnect your ESC and you're good.
Edit: Just saw you guys posted the same thing...err what they said!
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
86White_T/A305
Aug 17, 2015 12:16 AM
