What do these intake bore passages do?
Old Dec 17, 2003 | 02:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Ok I am getting ready to bore my edelbrock TBI intake to 2". Beofre I attempt this I have a quick question. Upon a closer look there appears to be two openings that are att he top of each bore. They are a rough hole and have do to something with air since they are right under the TBI unit and in the bore. I do not want to cut to close if I will open this hole up. I may not bore it to 2" but instead to 1.75 with a chamfer to smooth out the opening. besides the fron tand rear crossovers does anyone know where the water passages go in an intake manifold. They wouldn't be near the bores would they. If they are I may have to rethink this.
Old Dec 17, 2003 | 03:21 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
I wouldnt worry about them to much, As long as u doing bore to much into them you dont have to worry about them cracking, a friend tried more then 2" he went to about 2.2 and cracked, so just a lil food for thought
Old Dec 17, 2003 | 03:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
He went 2.2 on the edelbrock one? Sweet!! I am not worried about cracking them but I am worried about uncovering another passage that is not suposed to be open. Like a water passage. That is what I have heard. The one bore only needs about 3/8" deepness of material to be moved but the onter one needs about 2" or so. That is the one I am worried about.
Old Dec 17, 2003 | 05:57 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I believe those are EGR ports. Just blow in it and see where air comes out ...or you could use an air compressor, I just think it would be more fun to make a flute out of your intake :lala:
Old Dec 17, 2003 | 06:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well if it is EGR than I can relax. I plan on getting rid of the EGR so that won't be an issue. However that makes a lot of sense now.
Old Dec 17, 2003 | 08:49 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
It IS the EGR. I have one bored to 2.040 safely. It's for sale cause I can't bore this thing for my 1.75 dia distributor.
edit: just noticed yours is Edelbrock. Mine's a stocker.
Old Dec 17, 2003 | 09:22 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea I am really trying to find someone with a bored edelbrock one. those EGR passages are sort close and I do not want to make them bigger. I heard through someone that their buddy did it safely to 2.2"
Old Dec 17, 2003 | 11:27 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
I don't think the size of those outlets really matter, I mean they can only flow out what they get in and that's controlled by the EGR valve...but I could be wrong.
Old Dec 18, 2003 | 06:14 PM
25THRSS's Avatar
If you plan on getting rid of egr just fill them with jb weld like I plan to do.
Old Dec 18, 2003 | 06:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thats a good idea.
Old Dec 18, 2003 | 06:20 PM
25THRSS's Avatar
BTW, on my LS1, I have a ported stock throttle body, with jb weld covering the huge gap the factory put in it and everything is fine. JB weld is good stuff.
Old Dec 18, 2003 | 06:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What exacty is JB weld?
Old Dec 18, 2003 | 08:54 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
shifty, jb weld is basically a cold welding product. it comes in two parts and you place one part on the area, mix in the next and mix them together and a chemical reaction occurs making a "compound as hard and tough as steel ". kyle used it on the f.o.r.d on the gas tank, b/c the idiot who had it before him put an amp in and just used drywall screws in and screwed them in which punctured the gas tank. he said it still is holding well to this day and is very easy to use. here's the website. http://www.jbweld.net/coldweld.html
Old Dec 18, 2003 | 09:00 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
a thought just occured to me, you may, big may, but you may be able to use this on that spot where the hanger ripped off. but that's just a thought.
Old Dec 18, 2003 | 09:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hey thanks man, you learn something new everyday. I saw a post where someone made an air foil out of it for their LT1. I have heard that it can flake over time.
Old Dec 19, 2003 | 01:13 AM
Snowdog 91 Formula's Avatar
Weiand 300-66/300-49
If all else fails go and get a Holley/Weiand 300-66.
Old Dec 19, 2003 | 03:11 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
That's what I'll be using.
Old Dec 19, 2003 | 07:18 PM
25THRSS's Avatar
Here is a pic of what the inside of my throttle body looks like. You can see where the jb weld filled in the massive gaping hole in the stock throttle body and smoothed it out pretty well. It holds up great and is rock solid.
http://www.bauer-racing.com/throttle...pe%20Front.JPG
Old Dec 22, 2003 | 11:48 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hey wow thats looks great. Is the JB wled the brown spot with the two drilled holes in it? If it isn't than you did a great job of blending it in.
Old Dec 22, 2003 | 12:37 PM
25THRSS's Avatar
yeap, that's the jb weld. Unfortunately, that is not an actual picture of my own throttle body. That is just an example, but mine looks almost identical.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
john204481
Sep 7, 2015 03:22 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
