Need Help With New Setup Decision!!
Old Dec 22, 2003 | 03:11 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Ok first off the ole' 305 might have a rod knock at idle. Or it may be a cracked flywheel, this has yet to be determined. Anyway if it ends up being a rod knock I have come upon a freshly rebuilt 327 with a forged bottom end, short block only. For 500 dollars. So I figure I would spend atleast that much if not more on a 350 rebuild to get the parts I want which this 327 already has.
My vortec's will bolt right up with the 58 cc chambers, so should I go LT1 cam or ZZ4 to still to be able to use tbi? I would probably switch to a holley 670 tbi in the process. Or should I go ahead and throw in a Performer RPM cam or something with a carb which should yield near 400 hp? Since it's already a good bottom end I'm thinking the carb route would be nice with a power adder later this year.
Let me know what you think.
Old Dec 22, 2003 | 03:06 PM
Brent's Avatar
I'd verify the compression ratio before you figure on anything else.
-58cc heads
-.025" deck height (stock)
-.028" x 4.1" GM head gasket #10105117
-flat top pistons with 6cc valve relief's
will result in roughly 9.9:1 compression ratio
If the block has been decked or the pistons have smaller reliefs (or domes) compression will be higher..... probably too much for the LT1 or ZZ4 cam.
Stay away from the Edelbrock cams. They are old tech. New lobe profiles offer the same power with better part throttle operation.
Personally I'd run something close to the ZZ4 specs. You don't mention whether this 327 is based on a roller block or is an older casting. It'll be much less costly to run a flat tappet cam if it is an older block.
Old Dec 22, 2003 | 03:43 PM
Car: 89 Camaro RS
Engine: 305 TBI
Well I havent got to see the motor yet but I'm betting it's an old casting, not for sure yet though. I think I'm running close to 10 now on compression, my vortecs have been milled down .030 and I"m using a .017 steel head gasket.
You think maybe the ZZ4 cam or LT4 hot cam then? Might have to go carb with a cam that big, to much tuning involved.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
