heads
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Vortecs with a thin head gasket so that you don't lose to much compression. You will need a vortec intake though. However, easily transferable to your 350.
You can angle mill the vortecs to get them down into the range of your 305 heads. Add in a set of thin, rubber coated steel felpro gaskets you can actually raise compression while putting on a set of vortec heads...
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
