TBI internal fuel pressure regulator adjustment.
Old Dec 27, 2003 | 09:35 PM
Charlo's Avatar
I freshened up my tb with new gaskets and cleaned everything thoroughly today. While I had it apart I thought I would increase the fuel pressure a little. I backed out that screw about 3 turns decresing the springs resting length a little. The little external indicator moved about 1/16th.
Did I do it correctly or did I mess up?
How much did i change the FP in your guess if I did it correctly?
Charlo
Old Dec 27, 2003 | 11:15 PM
steve8586iroc's Avatar
I belive you turned the screw the wrong way. The best thing to do is to add a fuel pressure gage in the high pressure fuel line and then adjust the regulator.
Steve
Old Dec 27, 2003 | 11:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need to screw it in to increase the pressure. Typically every 2.5 turns is 1 PSI of increase. You need to data log to varify how your adjustments are doing correctly.
Old Dec 28, 2003 | 02:32 AM
Charlo's Avatar
Thats what i was afraid of.
Thanks guys.
Charlo
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
