305 to 350 tbi what do i need?
Old Dec 29, 2003 | 04:14 PM
vansrider98's Avatar
Car: 1992 Camaro RS
Engine: L03 305 TBI
I have a 92 camaro with a 305 tbi motor and I want to switch to a 350. What motor years do I need to look for? Can I use the GM 350/330 motor or will it not work cause of the vortec heads. The reason I am asking is because I have heard the the bolt's angles into the heads differ from certain years. Anyone I need some help. Also do I need to change to 350 injectors?
Old Dec 29, 2003 | 06:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can use the GM 330 with great success. The main thing is that you will need a new chip, 350 knock sensor, larger injectors and a few other goodies. It is pretty simple when you break it down. As for bolt hole angles; using vortec heads will require you to use a vortec intake. Also they do not have internal EGR passage and you either have to have an external EGR or program it out of the chip. Try a search and you will find enouhg stuff to read for days. Good luck
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
