External FPR Location
Old Dec 31, 2003 | 12:13 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Does an external fpr need to be located as close as possible to the TB, or would it make any difference at all?
The reason I ask is, if one were trying to maintain a semi-stock appearance, you wouldn't want an external fpr exposed. This would draw less attention by the smog *****, track techs, etc.
Old Dec 31, 2003 | 01:18 AM
JPrevost's Avatar
Car: 91 Red Sled
It doesn't matter in 98% of the applications. When you get into minimal cross sections and there flow potential it MIGHT matter. Even then it usually doesn't. Put it anywhere so long as the injectors are seeing pressure and fuel will flow.
Old Dec 31, 2003 | 01:34 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Great! If the regulator is vac referenced, would a lengthy vac hose cause a delay in the transition from a high vac to a low vac situation?
Nick McCardle
Sep 10, 2015 08:36 PM
Jlanz55
Sep 6, 2015 02:35 PM
Strick1
Sep 4, 2015 07:11 AM
tonys91rs
Sep 2, 2015 07:07 PM
