New 350 bin (check it out)
Old Jan 16, 2004 | 05:40 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Ok guys I've been looking through some bins lately and roughed out one for the 350 (check sig for setup) I'll be dropping in soon by modifying the stock AXKW bin file. Please check it out for me and tell me what you think of it. I reworked the main spark advance table and just swapped in the ANLU VE table. I'm still not positive on how well done the spark table is though so any input on it would be great.
Old Jan 16, 2004 | 05:44 AM
BronYrAur's Avatar
Engine: 305 TBI
Download and change .bmp to .bin...
File Type: bmp
Old Jan 16, 2004 | 04:17 PM
BronYrAur's Avatar
Engine: 305 TBI
TTT
Old Jan 16, 2004 | 04:42 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
BronY-
Nice car-
I had the AXKW chip and ripped the fuel and spark tables from an ANLU chip. That got me pretty close. It took more tuning, I remember intially having some knock at ~1800 to 3000RPM and low MAP, but tuning has eliminated that.
Here is a thread regarding my setup and related info: https://www.thirdgen.org/techbb2/sho...=AXKW+AND+ANLU
Best luck-
S-D
Old Jan 16, 2004 | 04:59 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks S-D. I basically used the VE map from the ANLU like you did but I looked through a 730 AUJP bin for a L98 and used that as a basis for my spark advance table in my bin. The TPI spark table is quite a bit more aggressive than the stock table but I think since I have an L98 longblock with the same heads and cam the AUJP was programmed for it should work out ok.
I don't have a programmer yet just the datalogging stuff for now. I've been waiting for the Prominator, hoping that will come out and I can just get that and not have to get a stand-alone programmer.
p.s. where are you at in the Chicago area?
Old Jan 17, 2004 | 12:45 PM
Car: 1991 RS
Sounds like a good plan- any additional head start to reduce the logging/reviewing/bin adjust/burn/re-install loop is a plus.
I wish they'd get that Prominator out. That will take a ton of the hassle out of tuning.
BTW- I have a programmer and can burn your first shot bin onto a 2732A chip if you are in a pinch. If you need, just e-mail me.
To answer your question- I am north of Chicago- Due West of Gurnee (Great America and so on).
S-D
Old Jan 17, 2004 | 02:44 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks a lot for the offer! I may have to take you up on that but by the time I get everything together (probably around april or may) I might have the burning stuff, so we'll see. I'm probably about 45mins away from you just south on 294, south side of Chicago.
-Jim
Infested
May 22, 2018 11:56 PM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
Out-Cast
Aug 17, 2015 10:57 AM
gwade12
Aug 8, 2015 08:17 AM
