New Gtech times, a few questions...
Old Jan 23, 2004 | 11:48 PM
cas0484's Avatar
Car: 1994 25th Anniversary Trans Am
Engine: Lt1
Transmission: A4
I haven't gteched my car in a while so I decided to tonight. However I am confused on my 1/4 mile time. I only did it once and got a 15.12@ 97mph. I know that the gtech mph is usually a little bit higher but even at that isn't that speed high for that time? Why does my time suck but my speed decent? Also, my 0-60 was 6.5, a slight improvement from 6.66 last time. I think these times are pretty decent but after searching on the boards I see alot of guys with lo3's say they are running low 7's and mid 6's. I dunno if this is or not but oh well. I know that the best my friend's 92 Rs could pull was 7.94 with open air, 3.42's and a decent catback exhaust. Anyways, any ideas with my times?
Old Jan 24, 2004 | 03:01 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Those times arent that bad. The Lo5 heads are pretty restrictive and the cam is pretty weak to. I got the times in my sig with basically your same setup, but with drag radials and a holley 670. Oh and my car wasnt bored over, but still that doesnt make a huge difference. those times arent bad for only exhuast mods considering the engine.If your not planning on doing any major engine mods(new heads, cam , etc.) You could try 1.6 roller rockers to raise the lift on your cam a little, that would help. All in all those times are decent for a basically stock engine. You see some real nice times with gears,an intake, and a bigger throttle body aswell. Good Luck.
Old Jan 25, 2004 | 07:26 PM
cas0484's Avatar
Engine: Lt1
Transmission: A4
I am happy with those times for now. I will be getting my posi/gears as soon as I get my tax refund check. However, what's up with the mph? Isn't that kind of mph usually associated with mid to high 14's?
Old Jan 25, 2004 | 08:49 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
not really you have ron the 97 mph on the g-tech so its really 92 mph and that is about it,89 stock 5.7 is roughly 95-97 at 14.6,90-92 5.7 14.20-13.90 99-103mph..
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
