possible ET for dual tbi
Car: 82 T/A
Transmission: th350 w/ high stall C.
I have an 82 trans am that weighs 3100lbs.
It has a 2.93 posi , some traction aids(see sig) , 350 tranny with shift kit, and a 305 bored 0.030 over (310ci),9.5:1 compression, the engine is:
Crossfire Injected with;
-stock ecm and injectors
-slightly polished throttle tunnels(removed ridge)
-dual open element
- cowl induction
-heavily ported x-fire manifold(cleaned up rough edges, grinded ports and cut off sharp bends for increased air velocity) , gasket matched intake ports and cylinder head ports
- polished exhaust ports and bowl
- polished combustion chambers
-ported intake ports on cylinder heads and removed casting flash
-comp cams 252-AH12 computer friendly hydraulic lifter cam
206*/212* duration at 0.050 and .425''/.440'' lift
and 112* lobe separation
-blue racer double roller timing chain
-heddman 1 5/8 shorty headers
-custom 3'' single exhaust
-dynomax super turbo muffler
-carter 15psi fuel pump
from this setup, what would a safe prediction of my ET be?
-dual open element
- cowl induction
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
With the stock tune I would say low 15's. With a custom prom 14's are possible. But perdicting ET's is like buttholes, everyone has one and it stinks. You just gonna have to run it.
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Well, seems like a nice little build-up you've got there...only one thing I disagree with. Get rid of the super-turbo muffler and get the ultra flo.
I say with what you have now...mid to high 14's.
Chip tuning, and ultra flo muffler....high 13's isn't far fetched.
You might want to rethink your fuel pump, you could use one capable of higher pressure to better tune with. Also maybe some bigger injectors could be in your future. If you have access to a WB o2 meter it would sure help tuning alot.
One other thing that might make tuning a little simpler would be to switch to a newer ecm like a 746 or 747.
Steve
Steve
Car: 82 T/A
ok
hey STEVE8586 IRoc...
about switching to a newer ecm, like lets say an 87 tbi...
how hard is it, would I be albe to use existing wiring???
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
You should be running mid to high 14's if it is tuned decently. By tuned I mean FP and Timing, not a chip. Chip tuning would help further, but you should do what I just said w/o it. More than chip tuning getting a better gear and a 5 speed would help a TON. If you had that, I'd say you should be able to kiss 13's with great driving.
As for changing the ECM you need to make your own adapter harness that plugs into your car's harness and in to the 7747 ECM. Not hard, but somewhat time consuming. If you'll look at my sig, you'll see what is POSSIBLE with teh stock ECM and chip. Not Ideal I'm sure, but you can make it work.
-Tom
-Tom
codeysabatini
Nov 10, 2015 04:07 PM
jer4251
Sep 27, 2015 09:52 PM
