High pitch squeal when lightly press throttle
Car: 2002 Z28
i was getting that same exact squeal a few months ago then all the sudden it just went away, but every once in awhile i get a very low squeal. Not sure exactly what causes it and i would like to know what other people think.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would guess it is the IAC, i didn't download the video, but i would give the IAC a good cleaning with some carb cleaner, and see what that does.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would clean the whole TBI unit especailly underneith. There is a maze underthere of tiny passages and nooks and stuff and air that gets impeded could squeel. It may be a good time to do the unltimate mods along with a good scrub down.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I had the same problem and it was a major vacum leak. If it is a extremely loud high pitched squeel it is probably a vacume leak. If it is a lower pitched almost wine it could be the iac. My vacume leak was around the base of the tb. The gasket was acting like a reed in a wistle and making all kinds of noise when my throttle blades were close the leak.
