cam should i go with the lt1
Old Feb 21, 2004 | 11:06 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
ive got a lt1 cam but should i go with it im planning on getting 4.10's posi ive got full exhaust done and i got edelbrock 2'bore manifoldand a holley tbi unit on the way.also whats the most possible i could bore out the 305 block jus wondering. also my car is automatic but im getting a manual valve body and a racthet shifter.also i need to get something done about these heads i need to get them ported or something also how would i raise the comperssion like to 10:1 becaus i hear that the stock tbis are 8:1 some where around there.
Old Feb 21, 2004 | 11:14 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
stock compresion is 9.3:1
you are better off getting diffrent heads, porting the stockers isn't worth it.
i will hold of on cam recomendations until you pick heads.
i also woudn't bother with machine work on a 305, if you are doing a rebuild, you might as well rebuild a 350.
with any new cam/head combo, being an auto, you are probably going to want a stall, depending on the cam you pick, you will likely be in the 2600-3k range for the stall but that will depend on your cam.
Old Feb 21, 2004 | 03:38 PM
tbfirebird's Avatar
Engine: ??????????
hey i read a mitchell book that the stock compersion for a 1989 firebird formula 305 tbi is 8:1 not 9
Old Feb 21, 2004 | 04:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is wrong. It is just as dewey said. Also 4.10's would be overkill for any 305. I would look at 3.42's or 3.73's. Like dewey said. The stock deads are garbage, the stock compression ratio is just fine for stock and or modded 305's and you are going to want to look at a stall. I would try a few searches to help you decide what to get for each stage of the car that you want to upgrade.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
