auto x-ray
Old Feb 23, 2004 | 07:21 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
auto x-ray
is this good
tps voltage .48
map .70
knock 1
Old Feb 24, 2004 | 05:28 PM
Engine: 5.8
Old Feb 24, 2004 | 05:39 PM
Engine: 5.8
what is normal
Old Feb 24, 2004 | 05:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your tps voltage is at the bare minimum at idle, your MAP is low, and your knock should be 0. I think the MAP is supposed to be close to two.
Old Feb 24, 2004 | 06:03 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Well just those numbers by themselves don't tell you much other than the tps is set correctly if you were at idle. You need to look at the whole picture. Knock counts are counts of knock in milliseconds. 1 millisecond could have been you closing your door, don't worry bout it. I get 10 when I shift just becuase my tranny shifts hard. When and where knock counts matter more than how many. If that is map voltage then it could be ok. Most cars idle with 30-50 kpa. I couldn't tell you what that is in volts. You need to drive your car around and see what it's doin. If auto x-ray doesn't log data for you to look at your got ripped. winaldl is free and logs date and does all kinds of cool things.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
