350 vs. 305 injectors
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I have the entire induction system from a truck that had a 350 TBI motor. Does the 350 setup use the same injectors? If so, can I (should I) swap them onto my existing 305 system? I will be swapping in a larger engine soon and will need to use my existing induction components for the time being.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 350 vs. 305 injectors
