Loopy Idle
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Loopy Idle
my brother has a 92 firebird that has a lopy idle it will idle up and down while driving and while sitting there... we are going nuts we thought it was the position sensor but we purchased a new one and not it check the egr and still no problems just replaced the oxygen sensor and still no luck him and i are pulling our heair out trying to figure this out any help would be great thanks
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
does it only happen when the car is warm, or does it do it any time? try cleaning out the idle air control, it's the little port with a connector with four wires on it, on the passenger side of the TBI unit. spray some carb cleaner in there while it's running, and see if it doesn't help. if it's really dirty, take the TBI unit off and clean it with a Q-tip.
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I've also seen many computer controlled cars running cams with not enough LSA that will do that cuz it'd driving the computer crazy and screwing up vaccume levels.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would make sure that you have a clean TBI unit and PVC valve. Take them off and clean them very well. There are tiny passages than can accumulate funk over time and not draw the right amount a vaccuum. Also, when was the last time you replaced the ful filter. A clogging fuel filter will cause idel problems yet remain smooth when cruising. Hwoa re your injector spraying? Are they an even triangle shape without any drips or spits?
Car: 91 camaro Z28
thanks guys i will check all of that and that should fix it it does it all times when it is warm or not and the injectors are spraying right:hail:
