SES light and no code?
Old Mar 22, 2004 | 01:56 PM
Z69's Avatar
Z69
Guy I know has this problem.
SES Light comes in every once in a while, but no codes stored.
Car has 300K on it.
Car ocassionally falls on it's face while driving. Sometimes can't give it hardly any throttle at all. Wouldn't start once.
Changed the following.
Coil, cap, rotor, wires, plugs,oil,MAP.
Checked ign. module, FP is 12psi.
Thoughts?
Old Mar 22, 2004 | 02:12 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
By not storing codes, I assume it's giving a code 12 only... perhaps it's really throwing a code 12 (no distributor reference pulse).. ignition module or coil getting ready to fry. Just an idea.
Old Mar 22, 2004 | 02:55 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well you if you have 300,000 miles than you are about due to cash in the LO3 for good. Your problems are most likely past general repiars.
Old Mar 22, 2004 | 07:52 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I'm just ticking past 290k.. only smokes on startup.. I don't see the problem with all those miles
*edit* then again.. I have a wednesday car. others experiences may vary radically.
Old Mar 22, 2004 | 11:11 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
From the looks of it your not in an LO3...if you do have a 383, something tells me it isn't stock, and your ECU might not be comunicating properly or something....
Bruce (90RS305)
90RS305's Avatar
That and maybe a wire got crossed somewhere that goes to the little light bulb...
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Omega
Aug 10, 2015 12:46 PM
