Cleaning tbi unit
Old Mar 24, 2004 | 05:32 PM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
Cleaning tbi unit
I want to clena my tbi unit but should be worried about taking it apart. I had tpi and I can take those apart with my eyse closed and do everything I need to do but this is my first tbi. Also the car has sort of a miss while in drive and stopped. It sort of jumps but its fine when I press the gas. Any idea what this could be??
Old Mar 24, 2004 | 07:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Cleaning tbi unit
Just take it off and use a good amount of carb cleaner. I use a tooth brush as well to scrub all of the funk out. It is really easy to do and is a good way of keeping your vacuum passages clean.
Old Jan 31, 2013 | 02:32 PM
the blue one's Avatar
Car: 1988 base
Engine: 305 tbi
i had a problem after i took everything apart and put it together, it would vibrate while ideling. make sure you get your vacume tubes hooked back up properly
Old Feb 1, 2013 | 09:14 PM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
I had a problem at idle in gear the dizzy was the problem it
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
92camaroJoe
Aug 13, 2015 06:07 AM
