is a 4bbl TBI any good?
Old Mar 24, 2004 | 11:58 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i was thinking, would i gain anything from upgrading to a 4bbl TBI?
thanks!
Old Mar 25, 2004 | 12:25 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
On a stock motor, no. Even a 454 tbi would be too much.
Old Mar 25, 2004 | 12:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what if i supercharged it ?
Old Mar 25, 2004 | 07:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Nope again. Just look at r90camarors who is planning on hitting high 11's with his 383 TBI. He will still be usining the 2BBl holley 670 unit. He will see how far he can take it before the limits are reached on the 2BBL.
Old Mar 25, 2004 | 07:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
fueling is the biggest issue, if i were to supercharge mine, a 4bbl would be a for sure. on a 305 with a small amount of boost, and a boost referenced FPR or FMU, you could probably get away with a 2bbl
Old Mar 25, 2004 | 01:20 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The easiest, cheapest way to get power is to do mods to the drive train. A budget cam, home cooked heads, gears, tuning, etc. will all do wonders for the L03. Theres no need to drop thoudands of dollars on a SC kit or anything like that to get some extra power.
Old Mar 25, 2004 | 08:25 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Personally, I plan to use a 4 barrel MPFI setup when I get the money. One thing for sure is, getting air and fuel would not be your weak point on the car. One thing you could consider is the 2 barrel MPFI kit. That should add 25-30 extra horses or so. Doesn't cost as much as a supercharger either. Just a thought.
Old Mar 25, 2004 | 11:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanks, only reason i asked was i was at my auto parts store and i noticed a 4bbl TBI on display.. so i was just curious, wasnt seriously pondering purchasing one
but this mpfi kit... explain a bit plz?
Old Mar 26, 2004 | 01:06 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Well, here are a couple of pics. One is the 4 brl and one is the 2 brl.
Old Mar 26, 2004 | 01:07 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
here is the 4 brl.
Old Mar 26, 2004 | 03:02 PM
614Streets's Avatar
You could not run a 2 barrel tbi on a v8 with a blower.
Old Mar 26, 2004 | 03:35 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Actually you can..
Holley kit 77-144CSBE-1 is designed for 93-95 LO5 trucks, retains most stock components, including the throttle body/injectors/air cleaner, comes with multiple pulleys, and even includes a chip for 93-95 LO5s (albeit useless to us).
Just don't try this with 45pph LO3 injectors
Old Mar 26, 2004 | 03:36 PM
Berlinetta's Avatar
that two barrel setup is the edelbrock kit. You should done a search. I had a huge post dealing w/ that kit. Basically, edelbrock says it wont work on a TBI car but i think they're FOS and are saying that only because it has not gotten a emissions exemption number yet for use on cars. Because the chip they send wouldn't work in our cars, you'd have to tune your own and im not sure how to tune a chip to run 8 injectors instead of two. Stick w/ TBI unless you want a real adventure
You dont need the 4bbl for your car. I can't possibly see any justification for it. That things flows something like a 1000 cfm and you definitely don't need to flow that much air. In fact, you'd probably lose enough low end torque that the car would be unenjoyable to drive on the street and you'd only see mild gains on the top end. Definitely go w/ the first step bolt ons. You'd be much happier, not to mention, you'd be going faster that way.
MustangBeater20
Oct 29, 2022 09:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
