installing the lt1 cam
Old Mar 25, 2004 | 09:55 AM
TMoNeE's Avatar
Car: 87 Z28
ok, ive read the forums, and the history, and i get differing stuff....
What is required to install with the cam.
I know valvesprings are recommended, but what about like pushrods and stuff.
What SHOULD you install when installing the cam... thanks.
Old Mar 25, 2004 | 10:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
pushrods and lifters form your current stuff is re-usable. valvesprings are recomended. you will need intake gaskets, timing chain gasket, and valve cover gaskets. i would suggest a timing chain also, chances are yours is worn. also, remeber to rent a balancer puller, if you don't have one.
Old Mar 25, 2004 | 11:45 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dewey hit it on the head. Any timing cover gasket should also come with the water pump gaskets as well. Also, intake gaskets usually come with the distributor and thermostat gaskets as well. Don't forget RTV, gasket scrapers, and the balancer installer. It makes thing much easier when the BFH trick doesn't work.
Old Mar 26, 2004 | 05:51 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Definetly get a harmonic balancer installer also. I watched a buddy of mine ruin his crank threads in a brand new GM crate engine because he just tried to use the bolt to reinstall the balancer. Sad day that was lol.
Didn't matter in the long run because he drove it home from the garage and it has sat since....brand new motor and it still wont run
Old Mar 26, 2004 | 06:11 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Don't forget these items/tools:
11 quarts of oil
2 gallons of coolant
1 bottle of Fast Orange
1 tube of RTV
Harmonic balancer puller and installer
Cam remover tool OR three long bolts to fit in (3/8"?)
Cam swap gaskets: intake, timing cover, etc
You're gonna want a grinder to get the timing cover back on easilly
Be sure you know how to do the following:
set a distributor and know the firing order (18736572)
set valve lash properly
This thread should provide a lot of help and pictures
Old Mar 26, 2004 | 11:07 AM
TMoNeE's Avatar
Car: 87 Z28
Thanks guys, and thanks for that link.
btw, Shifty, I read in that other post that you have a good tech article for an LT1 cam install... can you send that to me, tmonee98@yahoo.com. Thanks
Old Mar 26, 2004 | 11:42 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am still working on it but I will make it available to people when I am done.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
Mar 10, 2016 10:35 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
drathaar907
Aug 6, 2015 04:20 PM
