Correct Walbo p/n?...Overkill??
Old Mar 27, 2004 | 04:11 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
OK, I almost totally forgot about an upgraded fuel pump for my 350 swap, but is this what I'm looking for?
http://www.jdsperformance.com/index....&initemuid=437
Also, yall don't think 255 is too much? I mean, would a smaller and less expensive pump do the job? If I remember correctly, a 255 pump will support like 800 HP.
Thanks.
Old Mar 27, 2004 | 07:51 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
they make a 190 ltr/hr pump as well and i think that would works better with tbi . i think i read somewhere that it stock fuel pressure regulator can handle it just fine but the 255 requires an aftermarket regulator and ive read that some people have had problems getting the fuel pressure down into tbi range even with the new regulator. When i do my motor swap im going with the 190 , its more then enough unless you plan on goiing to tpi or something liek that in the future. search on the tbi board for the walbo pump .. its been talked about alot.
hope this helps
Old Mar 27, 2004 | 07:54 AM
bbtaz97's Avatar
Car: 91 RS
http://www.autoperformanceengineering.com/
sells the 190pump for 75 dollers.. just thorugh i would point that out..
Old Mar 27, 2004 | 07:56 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
My 255 floods out my stock regulator at low pressure , like 15 or lower, seems to keep a constant pressure above that though. The 190 would have been plenty for me.
Old Mar 27, 2004 | 12:41 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The 190 will be more than enough. Some just like the old saying "if some is good more is better."
Old Mar 27, 2004 | 01:13 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I'm running the 190.
Old Mar 28, 2004 | 11:49 PM
Car: 91 RS
Engine: 350 TBI
Thanks for the link. I went ahead and ordered it. Hopefully it does the trick and I've remembered everything I'll need for this swap.
InfernalVortex
Apr 20, 2021 11:31 AM
3rd gen money
Oct 11, 2019 09:57 PM
jaridjohn
Oct 5, 2015 07:01 AM
sjorgens
Oct 1, 2015 07:54 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
