emissions help?
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
emissions help?
I have failed emissions 3 times. first test I failed HC and CO but passed NOX. Second test I just cleaned out the throtthe body, removed my hypercrap chip/ replaced with stocker and ran 2 bottles of dry gas and the damn HC went up. The last test I replaced O2 sensor, changed oil, distributor cap & rotor, PCV valve, checked spark plugs & wires-they looked good, and I failed all three (NOX went through the roof) HC & CO went down but not enough. I think the new O2 sensor is bad?
I do use a lot of oil but no more than usual and I have passed before. Now my exhaust smells like sh*t. Maybe Cat Converter should be repalced next. I do have to run high octane or I get ping. There is black smoke when I get on the throttle which makes me think it is running rich. My mechanic checked the timing and said it was good. How do I check for a rich condition? Where should I be looking next? EGR? How do I check that?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: emissions help?
Hotrodboba400
Dec 10, 2019 07:07 PM
