Weird Idle Problem
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Weird Idle Problem
After starting the car in the morning and letting it warm up for about 5 minutes, the cars idle decreases near the point of stalling, then it races back up to keep from dying. I'm thinking IAC but the shop replaced it about 10k ago and im not sure of the manufacturer, all i see is "made in mexico" on it lol. I don't have problems in the other gears and it drives great.
Plugs - 10k
Wires/Dist cap & rotor - 30k
Fuel Filter - 3k
Fuel Pump - 25k
Injection Service - 8k
Any suggestions?
Plugs - 10k
Fuel Filter - 3k
Fuel Pump - 25k
Any suggestions?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Weird Idle Problem
Plugs - 10k
Fuel Filter - 3k
Fuel Pump - 25k
Any suggestions?
Plugs - 10k
Fuel Filter - 3k
Fuel Pump - 25k
Any suggestions?
Car: Caprice
Engine: 5.0 305 LO3
I didnt know you can adjust an IAC? The dealer did say it was working within spec but on the low side, barely making it. Does it need adjustment or is it crap? I also just replaced a hose from the MAP to TBI that had a whole in it, that cured my rough idle while cold problem. Timing supposedly was reset by tech not to long ago also, but ill check.
Ghettobird52
Jul 5, 2024 11:18 PM
