fuel pressure guage?
Old Mar 30, 2004 | 10:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
is it possibe to hook up a fuel pressure guage to our TBI's? i think my fuel pump is going and id like to have the pressure gauge to check it at highway speeds cuz it runs fine at idle, plus it would be a good investment overall.
Old Mar 30, 2004 | 10:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes you can. You can hook it onto your feed lne and read your pressure at idle. Or you can fab it up and have it sit on top of your hood so you can read it at WOT. I would just data log to see what your fuel demands are. There are lots of posts out there on this. You will see that many people get the summit one for 20 bucks. Most people do this to make sure that their pump is not dying.
Old Mar 30, 2004 | 10:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thats exactly what i want? do u have the link at summit to the one specific to my TBI engine?
it is like a regular guage right? where u see the pressure while driving?
Old Mar 30, 2004 | 11:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It depends where you mount it. Most people can only see the reading when their car is dieling and the hood is open. I have yet to see anyone that has succesfully rigged one up to see while they are driving.
Old Mar 30, 2004 | 11:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
point me to the product and i will be the guinea pig
Old Mar 30, 2004 | 11:22 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will have to look. Just look on summit and jegs for their brand FP gage. They range from 20 to 50 bucks. The one you want is 30 I think. I have not done this mod and would hate to do the research for you
Old Mar 30, 2004 | 11:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
is this what you are talking about?
http://store.summitracing.com/partde...art=ATM%2D2172
Old Mar 31, 2004 | 01:56 AM
25THRSS's Avatar
If you are gonna run one inside the car use an electric guage. Shouldn't be too hard.
Old Mar 31, 2004 | 03:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
can someone give me a link to such item, im not quite sure what im searching for when i do look around lol
Old Mar 31, 2004 | 09:23 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You beat me to it. They make a nice elctric one that has a sending unit and such that goes under the hood. Than you can run the gague in a pillar inside your car. I have no idea how it would install but I can't see it being to hard. I beleive track tested makes it. But Autometer and others make one as well. You may want to call one of those compnay's and have them explain it to you better and help you with your application needs.
Old Mar 31, 2004 | 11:11 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
they're expensive
Old Mar 31, 2004 | 04:33 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
http://store.summitracing.com/partde...t=SUM%2D800260
Thats what I use.
Old Mar 31, 2004 | 05:27 PM
DM91RS's Avatar
Car: 91 RS
http://store.summitracing.com/partde...=NRD%2DD70060W
Works great.......install it anywhere you want to be able to see it ez.
Old Apr 1, 2004 | 07:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
will this one fit ok? im pretty clueless with this whole fuel pressure stuff, but once i buy it, i can hook it up pretty easy.
is 15psi enough or should i buy the 60psi model?
Old Apr 1, 2004 | 08:46 PM
25THRSS's Avatar
like I said, if you plan on putting it inside the car the electric is the only way to go. You won't pass tech at the track with a mechanical guage inside the car. If you don't plan on putting it inside the car then you'll be fine, but otherwise go electric.
Old Apr 1, 2004 | 11:00 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what do you mean it wouldnt pass inspection at the track if its mechanicle? is their a safety hazard involved?
i will check into electric ones then, though they look expensive, and now i believe my problem is the egr valve, so i may not need one so soon afterall
Old Apr 1, 2004 | 11:02 PM
25THRSS's Avatar
You can't run a fuel line inside the car. Think about it.
Old Apr 1, 2004 | 11:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok good point. so how does the electric ones work ?
Old Apr 1, 2004 | 11:05 PM
25THRSS's Avatar
there's a sending unit in the engine compartment that sends a signal to the enectric guage inside the car, much like how the factory did it with the other guages.
Old Apr 1, 2004 | 11:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks 25thrss
your helping me alot with this small detail stuff.
just giving u my gratitude
Old Apr 2, 2004 | 12:45 PM
Ronny's Avatar
i would think a long hose to gauge and then allow it to come into passanger window for testing purposes only. a passanger could hold it or could be duct taped to inside window very temporarily.
Old Apr 3, 2004 | 12:24 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I have this electric A/F gauge on my a-pillar:
SUM-G2986 (summit p/n)
. . . in this Autometer pod:
ATM-10201 (summit p/n)
I also have an analog gauge mounted in my engine bay in the feed line similiar to what Chuck posted.
The electric gauge plugs into the O2 sensor. It's very easy, and VERY sweet looking.
Old Apr 5, 2004 | 10:52 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
How well does it work?? Cuz I was thinking about getting one as well.
Old Apr 6, 2004 | 09:13 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
buzz do you pics of how you mounted your guage? , or was there something you bought to mount them, i believe i seen something before that can hold up to 3 guages on the A pillar, not sure where i saw it though..im plannong on getting one too, should i get the 15 or 60 psi one
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
