Top Speeds of a 305 TBI
Old Apr 10, 2004 | 06:06 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I was just wondering how fast ya'll have taken the LO3? I've gotten it up to 110 before and she still seemed to pull pretty damn hard, so I was wondering how much further I could push her.
Old Apr 10, 2004 | 06:36 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
ive had mine to 110 also.... i read somewhere that there is a tbi cutoff at 115 but you can modify it.... i think its on the site under tech articles....
Old Apr 10, 2004 | 07:39 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Not sure how fast it can go. But when you get that SOB up to 110mph it starts rattling like crazy!
Old Apr 10, 2004 | 08:53 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i have had mine to around 125-130. I think i could go even faster than that, but i dont think ill try.
Old Apr 10, 2004 | 09:06 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
About 120 with 2 passengers in the car and I still had a bit more room on the throttle. I figure I could have got it up to about 130. It was smooth too.
Old Apr 10, 2004 | 09:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No 305 TBI will go past 112 unless you have deleted the speed limiter in the chip. You could also bypass the limiter (via tech article) manually and achieve higher speeds. If your speedo tells you else it is off or you have a different tire or gear size.
Old Apr 10, 2004 | 10:28 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I've hit the speed limiter as well, and I think there's more room left in her. That was with the stock 2.73's when I did that, so once she got up there, she cruised effortlessly.:hail:
Old Apr 11, 2004 | 12:06 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Well... no 89+ tbi. If your an owner of an 88 model, there is no speed limiter, which means on a hill with a good stiff breeze to your back, you could probably get it up to around 125.
Old Apr 11, 2004 | 02:23 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
In the manual versions with the 3.08's (which I have) the govenor is set, well at least on mine, at 119mph (varified by multiple cars capable of higher speeds). Not only have I hit it MANY times, but my lil' LO3 is still pulling really hard when I hit it. I wanna get that thing off there sooo bad and have my buddy tail me in his GT so I can see what my real top speed is.
Bruce (90RS305)
Old Apr 11, 2004 | 03:31 AM
25THRSS's Avatar
Bruce (90RS305)
Your speedo is off or whatever method you used is wrong. The speed limiter is set to 112 mph, which is the speed rating of the tires. If it was set higher there would be potential for major law suits and gm would not do that.
Old Apr 11, 2004 | 05:06 AM
90RS305's Avatar
hmmm...maybe something is wrong with my computer? I've had my friend in his GT and my other buddy in a lancer pace me and the GT came up 118 and the lancer came up 120. Not saying your wrong, just curious as to why that might be off...
Bruce (90RS305)
Old Apr 11, 2004 | 09:24 AM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
i dont know how fast i had my car up to i had the needle pinned to the trip odometer so take your measurement from there
Old Apr 11, 2004 | 11:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Bruce (90RS305)
There is some variance withing 5mph or so. Some are 110 and others are around 120. Tire size and a gears can play into it as well. I know you are stock but chances are your speedo is off just like our tachs are. I have done the speed measureing method as you decribed by riding ext to someone who is at a cetain speed. However, their speedos are off as well. Digital ones aren't off that bad but it is hard to get two cars to go the same speed.
Old Apr 11, 2004 | 11:41 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Speed governor aside, I know my car has gone at least 120 mph. My wife and I were going down an old country road with me in the lead, and her speedo was at 120 and she couldn’t catch me.
I know her speedo to be true because just the other day I was driving by one of those radars that flashes your speed at you, and it said I was going 44 mph and her speedo said 45.
Old Apr 11, 2004 | 11:49 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hers is still most liekly off. The higher you go the more they are off. Pass the same radar thing going 120 and I bet it will say 112 or so. Most speedos out there are really off the higher speeds go.
Old Apr 11, 2004 | 11:58 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I hit 125 the other night. Cable driven speedo's are suppose to be more inaccurate the higher the speed.
Old Apr 11, 2004 | 01:16 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
ive been up to about 147 before (with TBI measured via rpm, gearing, and tire size so its accurate) it had way more in it but I got Skerrrrrd
top speed isnt all that fun anyways.. acceleration is where its at
Old Apr 11, 2004 | 05:12 PM
Engine: L69
Transmission: A4
At 110 I didnt have any vibration at all and i know it has the stock drive shaft. Why is that? The only other noise I had was my little brother screaming at me telling to slow down
Old Apr 11, 2004 | 05:17 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It depends on the shaft. The steel shaft in my RS never vibrated at all all the way up to the limiter. One the other hand the steel shaft in my 95 will vibrate at 90. It just depends.
Old Apr 11, 2004 | 08:32 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
dunnno what ive had mine up to cause the speedo is unplugged
but she was a floatin and everything on the sides of the road was a blur
Old Apr 12, 2004 | 12:46 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
One of my fondest memories in my car is when I was cruising down the road with my friend and she says "Brian, how fast are we going?" and I replied "I'm not sure, I ran out of speedometer a couple minutes ago."
Old Apr 12, 2004 | 04:33 PM
82Z28NAZ
Guest
Posts: n/a
not really sure.. the speedo only reads 120.. she went quite a ways after that
Old Apr 12, 2004 | 04:58 PM
dopplereffect's Avatar
Car: 91 firebird TBI
Engine: Three SLow Five. LO3
Transmission: MAN 5 SPD B0RG WARNER, 77MM, 2.95
i took mine 120+ because i raced a z28 and we both were flyin
Old Apr 12, 2004 | 05:26 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
well i have been clocked at 127 in my 88 k2500 pickup by a buddy of mine that has a gun. that was nuts 6000 pound trucks with 33" mud tires and a plow should not go that fast. but i have a 350 too
Old Apr 12, 2004 | 05:40 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Unless you have larger tires or deleted the limiter out of the chip your 89 and later 305 TBI car will not go past 112. I promise you. The speedos, just like every other GM one out there, get progressivly less accratue as speeds increase. It is hard to judge speed even if someone is pacing you. I thought I was goin 125 when I was running behind my roomates 02 SS when in fact he was going 135 and I was stuck bouncing off the limiter at 117 (larger tires). Even though the car may seem like it is going the same speed as you chances are it is not and it too has a inaccurate speedo.
Old Apr 12, 2004 | 05:44 PM
Car: 91 RS
Engine: 350 TBI
Just keep goin' until the computer kicks your RPM's down, then you know you've reached the end.
That's what I did in my mother's lumina a few years back. The sad thing is, that it didn't kick in until 120, which means I've gone faster in my mother's lumina than in my camaro.
Old Apr 12, 2004 | 05:48 PM
c4boom's Avatar
Engine: l98 and lo5
thats y you use win adl or find a cop buddy that is able to bring his radar gun home.
Old Apr 12, 2004 | 06:12 PM
82Z28NAZ
Guest
Posts: n/a
..... that would be a deleted limiter right out of my chip
Old Apr 12, 2004 | 08:44 PM
kammi10's Avatar
Car: 1989 camaro
in my 89 i was cruising down a backroad and i was testing her out and i got all the way past 120 on the speedo with a friend right in front of me and his car shuts off at 109 on radar and i blew past him leik he was sittin still so must be my limiter is not connected
Old Apr 12, 2004 | 09:31 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
The highest I've had mine is 110, damn thing still had 1000 rpms left before redline.
I rember tryin to top it out and I went over a shallow bump. That was scary, I was suddenly weightless then scrape, float scrape.
Old Apr 13, 2004 | 09:36 AM
GhostRacer23's Avatar
Car: 83 Z-28
Engine: 305 Cross Fire Injection
Transmission: stock auto
I can only get mine to about 105-110 (? i have the double sided speedo stock from my 83), but following my buddie in his jetta we both got up to 120. I think it was cuz he was in front of me blocking the wind though, those headlights are just big air pockets trying to slow you down, and the law won't let me put covers on them. I have the stock auto tranny though, with the overdive that kicks off if you push the pedal down past 3/4 of the way, and at that speed if i do, its yellow lined in 3rd, so i don't want my car to go any faster than that.
Old Apr 13, 2004 | 10:02 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yes and no, headlight pockets included, the thirdgens still have a pretty good COD. IIRC EVERY thirdgen model has a .35 or lower COD, the formies are the lowest, i beleive .31 or so.
Old Apr 13, 2004 | 10:43 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup. I always use between .35 and .40 when I do nerd stuff with these cars. 4th gens are a bit better.
Old Apr 13, 2004 | 10:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
hmmm, i always thought i had seen that the 3rdgens had a lower COD, because of the reduced frontal area. :: shrugs :: it has been a while since i looked at the numbers.
Old Apr 13, 2004 | 11:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the speed limiter for the ANTT cars (like my 91) is set to 114.
you can verify that with a laptop if you want.
ive hit it many many times. including uphill... shes still pulling when it hits.
disconnecting the VSS enables you to exceed the limiter (since the ECM doesnt know its speed) and the code will disappear as soon as its plugged back in and the car moves.
Old Apr 13, 2004 | 11:45 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They do have a reduced frontal area but it is by no means stream lined. Stream lining a car will produce a much lower COD than frontal area alone.
Old Apr 13, 2004 | 03:33 PM
Ronny's Avatar
140 mph and they shut off the dyno at 6000 rpms.
Old Apr 13, 2004 | 03:38 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
im not sure about that shifty, the car of choice for stock bodied stuff at the bonneville salt flats is a thirdgen firebird. Fourths have been tried but failed, they tend to fly at like 220... granted that doesnt tell us anything about drag
Old Apr 13, 2004 | 03:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea the birds are better than camaros. The salt flat car was not based on drag only. I think they chose that car for a "coolness factor" over high tech aerodynamics.
Old Apr 13, 2004 | 06:10 PM
25THRSS's Avatar
Third gen's have a better drag Co than 4th gens, especially the 91-92 birds. IIRC, they were very close to the vette, if not better.
Old Apr 13, 2004 | 07:08 PM
AJ_92RS's Avatar
Normally you're a reasonable person, but I gotta do this..
While I'll agree that speedos are rarely accurate, they don't progressively get worse as speed increases.
Do you ever read Motor Trend, or Car & Driver? They clock the cars then post the readings compared to the speedo. The most they're off is 3mph, and they're consistant.
The chart will read like this.
Speedo - Actual
30mph - 27mph
40mph - 37mph
50mph - 47mph
60mph - 57mph
Saying a speedo is off 8 mph at 120 is
Are you in denial that a 305 TBI will actually break 120mph or something?
Old Apr 13, 2004 | 07:20 PM
  #42
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
they wont do it unless the speed limiter is eliminated or its an 88
as for motor trend, they test brand new cars with stock size tires and wheels. Theres no telling whats on a 15 year old thirdgen not to mention the fact that alot of thirdgen ownership is 17 year old bull-****ters
Old Apr 13, 2004 | 07:37 PM
  #43
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
Speedos are often off by a percentage, so they get worse as the speed gets higher...
Old Apr 13, 2004 | 08:08 PM
  #44
AJ_92RS's Avatar
And your point is???
Mine was removed. I had a Jet Stage II chip for ~2 yrs, and before that day I never knew the speed limiter was gone. It was probably best that way.
That's all true, but that doesn't mean the speedo becomes more incorrect as speed increases.
It's a gear driven device. Regardless if the actual speedo is electric or not, the signal is still taken from the mechanical movement of the speedometer gear. The gear ratio does not change as speed increases.
Old Apr 13, 2004 | 09:41 PM
  #45
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Even though our speedos are gear drive they still rpoduce an electric signal and are not gear driven in the unit itself. It is half mechaical and half electrical. Therefore there is some error and it does not read 1:1. New car speedos are far more accurate since they are completely electric and are calibrated much better accroding to various engine parameters. A 305 TBI can go 120 without the limiter. In fact I am sure one can go to 130 in stock form if there is a stiff tail wind and downhill grade. I say they can't because of the limiter and not because of their lack of power. Pablo is 100% correct that our speedos get farther and farther off as speed increases. There is a lot of confusion goin on in here. You can put a 450hp minirammed 355 in your car but if the limiter is set at 112 the car will not go past that no matter how much power it makes. These cars always feel like they are going faster because you use so much road up to get to 110. These things do not pull up top. My daily driven 2.4L grand am pulls harder than a stock LO3 up top.
Old Apr 13, 2004 | 09:52 PM
  #46
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Id really have to see a bone stock LO3 hit 120+ mph. With a fresh tuneup my car bone stock was dead at 112 or 114, I barely hit the limiter.
Its quite a different story now.
Old Apr 14, 2004 | 06:06 AM
  #47
Dewey316's Avatar
Car: 1990 Camaro RS
chuck, i hit 130 on the front stretch of PIR.
Old Apr 14, 2004 | 08:14 AM
  #48
MrDude_1's Avatar
Car: 91 Camaro Vert
it is BECAUSE its a gear driven device that its off.. example:
i dont know the exact numbers, but you only have somthing like 5-7 drive and 5-7 driven gears to chose from (possibly less on the drive)
so you pick whatever is closest. so the RATIO is off ever so slightly....
this slight ratio diff makes only .01 mph diff at 10mph, but as you go faster, the ratio stays constant..... constantly off that is... so because its a ratio, it goes farther off depending on the speed so by the time you hit 50, its off by 2mph, and when you hit 150 its off by 12.... ect... (this can be expressed as a percent)
but how does this explain Motor Trend, or Car & Drivers test results?
simple. they test new cars.
new cars, like the 4thgens, operate diffrently... they dont use cables or little gears.
the VSS is turned at a specific speed... in the case of the 4thgen T56, 17 pulses per driveshaft rev.
the computer (or in my case, SGI box) gets this signal and takes into account tire size, rear end ratio, ect, and it mathmaticly changes the signal to the correct one, and sends it to the speedo. so its highly accurate.
why is it constantly off by a specific number then? because the needle is tweeked. plain and simple. the speedo itself is getting the signal for 15mph and pointing at 18 or 12 or whatever.
you have to keep in mind, you have a stepper motor, screwed/rivited into a piece of metal, with PRINTED plastic/paper over it and a piece of plastic pressed on over that. of course it might not all line up perfectly in production.. theres alot of tolerances there.
to compare what the computers seeing to what your speedo shows(and you can do this with any EFI thirdgen) hook your laptop up and watch the speed on it... this is what the ECM sees... compare that to what the speedo says... my 91 is dead on compared to the ECM.... but the speed its showing is only close..... my speedo is currently calibrated by doing the "pace a friend in the car next to you and mathmaticly figure the correction ratio from that" method.
its very very close though... compared to the radar signs cops put up, it was dead on with the 2.73s... sicne i put the 3.42 rear in, i havent found a speed sign...
Old Apr 14, 2004 | 08:16 AM
  #49
MrDude_1's Avatar
Car: 91 Camaro Vert
mine rushed up and then slammed on the limiter.... it felt like i tapped the brakes.
only mods were open element and catback. i know i went past 114 once, but i had the VSS disconnected so i dont know how far past....
Old Apr 14, 2004 | 09:15 AM
  #50
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
MrDude is 100% right on. He clearly explained mechanically why our speedos are off. :hail:
Dewey,
You must have had some long road
