misfire and stalling
Old Apr 12, 2004 | 09:28 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
ok my firebird has a slight missfire or something causing it to stall or for the tach to jump around. it started about a month ago but now with my headers it is most appearent. while idling it does these random pops... bout one per second. this causes the idle to drop to 400-450 and then jump up to 700 ish...sometimes it makes it stall...it happens both in and out of gear....my only mods are open element and hedman headers with custom 3" catback. i have recently replaced my O2, my plugs, cap, rotor, and wires..no matter how much i mess with timing i cannot fix it. any ideas?
Old Apr 12, 2004 | 10:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: misfire and stalling
What is your timing set at? Is your fuel pump dying?
Old Apr 12, 2004 | 10:45 PM
vjo90RS8's Avatar
Car: 2002 Z28
also try setting you idle, use the article in the tech article section "adjusting TPS and IAC"
Old Apr 13, 2004 | 05:35 AM
Car: 83 Camaro
Transmission: th350
right now i am running 4 degrees advanced. i doubt my fuel pump is going because i still have all my power up top. i have also tried moving the idle screw but it only changes for a minute then goes back one i start driving.
Old Apr 13, 2004 | 06:50 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Have you changed your fuel filter in the past 10,000 miles. A clogged one can make a car run fine at cruising speeds but stall it out at idle.
Old Apr 14, 2004 | 05:13 PM
Car: 83 Camaro
Transmission: th350
PLEASE HELP ME GUYS...it wasnt the fuel filter...but i did manage to waste 10 bucks of premium and burn half of my body with gasoline....any other ideas....im ready to light the damn car on fire
Old Apr 14, 2004 | 05:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Check your coil next. They can go out on a whim and make your car run like real poo.
NZKnight
Oct 15, 2015 02:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
