View Poll Results: ok whats wrong with my rig
stock fuel pump cant keep up with holley 670 with 65 pph injectors
100.00%
vfpr is screwd up
0%
restriction in a fuel line
0%
other if so please explane
0%
Voters: 6. You may not vote on this poll
ok what do you think is wrong hear
Old Apr 15, 2004 | 02:02 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i used a remote fuel pressuer gauge to test my l05 out today and it holds at 12.5 at idle but as soon as i put a load on it, blip the gas or any thing it drops to 10.
what do you think is up with it
Old Apr 15, 2004 | 04:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A. final answer. The stock TBI pump cannot even pump enough fluid to put out a candle.
Old Apr 15, 2004 | 04:55 PM
c4boom's Avatar
Engine: l98 and lo5
so i should pbly go get a new fuel pump any sugestions i only run need about 13 psi at wot and i do not want to have problems with the return setup keeping up
Old Apr 15, 2004 | 05:10 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You need way more than 13 psi at WOT. Even a stock LO3 needs about 15 PSI at WOT. Just get a high flow unit now so that when you add some more mods you will never be fuel deprived. Check out the Walbro units.
Old Apr 15, 2004 | 08:03 PM
c4boom's Avatar
Engine: l98 and lo5
i heard that people where having probs with the 255 units in that the return was not able to keep up and then they would be stuck with 15 16 and even presure over 19 at idle that is why i am so woried about going with a hi flow pump
Old Apr 15, 2004 | 09:01 PM
25THRSS's Avatar
try a 190 pump
Old Apr 15, 2004 | 10:54 PM
steve8586iroc's Avatar
I would be willing to bet that the return line is not the issue but the passage in the throttle body just being to small. Now I haven't looked at it lately but if it can be inlarged for more flow the i think the bigger pump would work ok.
Steve
Old Apr 16, 2004 | 01:47 PM
c4boom's Avatar
Engine: l98 and lo5
any one have the part #for the 190 lph pump that will work for the tbi
Old Apr 16, 2004 | 02:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Type in "Walbro fuel pump" in a search engine and you should get like 70 places that sell it. Prices vary but I have seen it as low as $115.
Old Apr 16, 2004 | 03:11 PM
25THRSS's Avatar
thunder racing at the top of the page sells it
Old Apr 16, 2004 | 03:22 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
http://www.autoperformanceengineering.com/
sells them...
190 ltr/hr kit
-FPG001 - $83
a.k.a. GCA701
The 190 ltr/hr pump kit has been installed in many TBI cars and trucks with excellent results. The fuel pressure regulator on the TBI engines appear to be large enough to return all the extra fuel to the tank.
Old Apr 16, 2004 | 06:55 PM
c4boom's Avatar
Engine: l98 and lo5
thank you very much
Old Apr 19, 2004 | 09:05 PM
c4boom's Avatar
Engine: l98 and lo5
update to all that said fuel pump you where right. i got the walbro 190 and i now it holds at 15 psi will drop about 1/4 a psi when i wack it but thats it. i am going to the track friday to see if this thing runs much better
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
