TBI blades stickin!!!
Old Apr 16, 2004 | 05:17 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
How do I resolve this problem, its a holley 2" TBI. I disconected the throttle cable and it still sticks... what could it be? and how do i rip this apart?
Old Apr 16, 2004 | 10:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TBI blades stickin!!!
Try spraying the throttle spring down with some carb cleaner and then some WD40. It should not stick unless it is completely gummed up with funk.
Old Apr 16, 2004 | 11:36 PM
steve8586iroc's Avatar
See how much play you have where the throttle shaft goes thru the throttle body. You probably have some ware in that area and it will cause a sticking problem.
Steve
Old Apr 17, 2004 | 08:40 AM
rsc350's Avatar
Car: 92 Camaro RS
YUP, its the spring... I took it off and they dont bind at all, cept it aint gumed up with crap, clean as a whistle...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
