idle problems
Old Apr 18, 2004 | 11:32 AM
raysbird's Avatar
Car: 1991 firebird
Transmission: 700 r-4
idle problems
hELLO, i am new to the boards. I have a 91 firebird 305 tbi with a very rough idle. I changed the iac motor last nite and tried to adjust according to the procedure i found on here. Now the car wont idle below 1200 rom in drive and the idle screw is completely off the throttle shaft.
Any help would be greatly appreciated.
Old Apr 18, 2004 | 05:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome to the baords. There are many things that are causing your symptoms. You could have burnt plug wires, bad coil, bad TPS, clogged fuel filter, or bad plugs. How long has the car gone before its last tune up?
Old Apr 18, 2004 | 06:46 PM
raysbird's Avatar
Car: 1991 firebird
idle problems
car was just tuned up shifty, still had a rough idle in closed loop so i changed the iac now i cant get it to idle below 1100 rpm in park and about 800 rpm in drive.
thanks for the reply.
Old Apr 20, 2004 | 07:22 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: idle problems
shouldn't the stop screw hold the throttle plates slightly open ? i look for a tps voltage of about .5 fully closed.
Old Apr 24, 2004 | 06:49 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Could be the initial timing was set incorrectly. Did you disconnect the timing control connecter link between the comp. and dist? When I bought my car, it ran like that. I checked it before I disconnected it and it was right on! I disconnected it like you should and it was 28* retarded. Poor comp. was trying to compensate for that and was screwing everthing up! Before I reset it, I was only getting 150mi to a tank of gas. after, 300+.
It could be too far advanced also!
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
