crossfire to 454 TB conversion
Old Apr 22, 2004 | 04:26 PM
Ronny's Avatar
crossfire to 454 TB
Any pointers on this conversion? i will be doing late next week hopefully. i think i have all the conversion components pre purchased.
Q#1. i see fuel comes in from front of engine currently. 454 TB fuel lines are to rear of TB. should i cut incomming fuel pressure line at
frame rail and splice in new and attach to firewall or whereever? return line remains as my FP gauge and FP REG is in front of engine off
alternator bracket.
Any help greatly appreciated.
__________________
previous crossfire vette 350 cid, xram, 2.0 TB's, 454 injectors, edel rpm aluminum 64 cc heads, crame 2040 cam 206/214 @.05, roller rockers, ceramic headers, dual exhaust, hooker aero chambers, 7747. coming 4/04 454 dual TB on howell adapter, INNOVATE WB02. 224/230 @.05 114 LSA, edelbrock oval air filter with K&N. coming 4/05 Holley 144 Procharger....
Old Apr 22, 2004 | 10:06 PM
steve8586iroc's Avatar
All camaro and corvette fuel lines up to 96 I think come in from the front then go to the back of the engine to the fuel rails or tbi. I wouldn't cut the hard line at all. If the exsisting system has a rubber line in it I would cut there or get some braided lines and use AN fittings to hook up where the rubber lines do. You can use standerd rubber gas line hose if you do not exceed the 25 psi rating.
Steve
Old Apr 23, 2004 | 09:22 AM
Ronny's Avatar
thanks. that clears it up. aeroquip sells a compression fitting to splice into hard lines. i already have. plus they have push on fittings with rubber hose. 1000 psi. quality stuff. i will just make the U bend to rear of TB. no sweat.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
NZKnight
Oct 15, 2015 02:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
