holley 670 injector wiring
Old Apr 25, 2004 | 08:57 AM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Ok, i am in the middle of a 350 swap and i bought a holley tbi off ebay. I have a 91 rs so the tps is a different style connector. I found a adapter on Turbo City's website, but i don't know how to connect the wiring on the injectors to the holley plug. I looked on holley's website and didn't see anything.
I am sure others have ran into this problem, so any input will be greatly appreaciated!
Old Apr 25, 2004 | 04:12 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
All you need is a tps connector from an '88-'90 tbi car. A salvage yard probably has one, or else you can order one from your local parts store. The wires are color coded and match.
As far as injector wiring goes, what unit do you have? Old style or new style injectors? If you have the new style, I can check mine and give you the info
Old Apr 25, 2004 | 07:36 PM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Thanks for your reply.
I have the old style injectors. But i was looking around Holley's website agian and found a terminal kit for the 502-2. Here is the link:
http://www.holley.com/HiOctn/ProdLin...FIA/534-4.html
It looks like everything I will need to connect to the tps and the injectors. The only problem is finding the correct wire for the pins on the injector plug.
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
