Low idle at first high latter on
Car: Firebird
I have a 92 firebird that had a broken TBI so I got one off ebay from a 92 camaro that went to carb, and now when I start the car the idle is where it should be but when I drive it around and stop at a stop light the idle gets stuck at 1000 rpm and sometimes 1500rpm. But when I start the car and take the rpm to 4000 and it let it go back to idle it goes back to the normal idle RPM. If I stop at a stop light and the idle is at 1500 I can turn off the car and start it back up the idle is back to where it should be.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check to make sure that your throttle linkage is connected properly. If not, it can pull on the throttle a bit and open it up causing your high idle. After that, make sure that you do not have a vacuum leak at the base of the TBI unit. Did you use a new gasket?
