Werid start ups
Old May 16, 2004 | 01:24 AM
92maroonbird's Avatar
Car: Firebird
Werid start ups
I have a 92 305 5-speed. Sometimes when I start the car, the car will all most die but before it dose it will take the rpm back up to 1500 rpm and will go back to almost dieing, it will repeat this over and over some times the car dies too. When it’s doing this if I floor it the car will be really weak and the rpm will go up to 1500 rpm and I’m flooring it! I have tried replacing the TBI gasket and using my spare injectors. And it’s still doing this. And the car takes a while to go back to idle like after stopping at a stoplight it will take 8 secs to get back to normal idle and some times when I start the car the car will go up to 2000 rpm and go back down to normal idling in 10 secs iv seen my friend start it and his car goes to 1000 and with in a sec its back to normal idling. I would really like help on the problem
Old May 16, 2004 | 12:57 PM
Car: Firebird
Sorry for makeing it so long
Old May 16, 2004 | 08:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check all of your vacuum lines going to the TBI unit. Pay attention to the one that goes to your MAP sensor. If that one is cracked or damaged you could have the symptoms described.
Old May 18, 2004 | 12:07 AM
Car: Firebird
The vacuum line going to the MAP sensor has already been replaced i'm about to replace the fule fliter and if that dosent work i'm going to replace all the vacuum lines going to the TBI unit dose that sound good?
Old May 18, 2004 | 12:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Your plan is fine and is a good precaution measure to prevent future problems.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
