BPW constant
Old Jun 17, 2004 | 06:06 PM
Casey_Butt's Avatar
BPW constant
I've just calculated that 90 lb/hr injectors on a 305 would require a BPW constant of 80.5. Normal for the 305 injectors is 134. Is this BPW (80.5) too low for the injector to function properly?
Casey
Old Jun 17, 2004 | 06:42 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No, that should be OK. I believe I was that low on mine for a while.
Old Jun 17, 2004 | 06:52 PM
Casey_Butt's Avatar
If I dropped the fuel pressure down to 9 psi from 13 psi that would put the BPW constant at 96.6. That would surely be operational, right? (I hope)
Old Jun 17, 2004 | 09:41 PM
25THRSS's Avatar
why not just run smaller injectors?
Old Jun 18, 2004 | 01:19 PM
Ronny's Avatar
i would run injector at GM recommended 12-13 lbs and get BPW accordingly. then tune away. why such large injectors? 305?
Old Jun 18, 2004 | 01:31 PM
Casey_Butt's Avatar
I got a good price on the large injectors ...and I'm planning on extensive engine mods, so I wanted "room to grow". 300 hp calls for about 90 lb/hr injectors anyway.
I'll think they should do fine. I'll try the low BPW at ~12-13 psi and step the idling up a notch to give them more on time at idle anyway. If that isn't tunable I'll drop the fuel pressure a bit and bump the BPW up accordingly. Should work, I believe.
Nighthawkf-117
Sep 24, 2015 02:47 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 3, 2015 07:08 PM
