tbi
Old Jul 8, 2004 | 04:44 AM
xdamxincx's Avatar
tbi
88 formula... wont start... replaced ecm ,fuel relay... fuel pump is working .. injectors not getting 12v,,,, is the iac suppose to be getting 12v as well ?
i mean if other sensors are bad should there not be a way to test them and track down the problem ?\
i have searched this topic intensely on this forum and nobody seems to finish the threads with any type of solution...
how does this help others ?
seems to me that there is no cure for tbi electrical problems from this message board.
Old Jul 8, 2004 | 10:41 AM
Z28GEN3's Avatar
https://www.thirdgen.org/techbb2/sho...iac+adjustment
perhaps you confused iac voltage with TPS voltage?
Old Jul 8, 2004 | 10:57 AM
PhilM's Avatar
Car: Accepting applications...
Have you checked the ignition module?
Old Jul 9, 2004 | 01:21 AM
xdamxincx's Avatar
ok my mistake i used the term iac when i should have used icm.. can i check to see if the icm is getting 12 v ? the car will run if i spray starting fluid in the tbi.
Old Jul 12, 2004 | 08:47 PM
xdamxincx's Avatar
hey can anyone help me here ????
still having problems.. wont start... fuel pump is not working either. anyone want to buy this pos ???
Old Jul 12, 2004 | 08:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you check the ignition module?
Old Jul 12, 2004 | 09:24 PM
xdamxincx's Avatar
replaced ignition module...
Old Jul 12, 2004 | 09:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Have you traced every wire on the harness to make sure that nothing has chewed threw them? Also, check all of your grounds to make sure none of them came loose. A bad ground will allow the car to turn but not always fire. I will keep thinking but I am running out of ideas. You might want to ask Trickster. He is the 3rd gen wiring genious.
Old Jul 12, 2004 | 10:14 PM
xdamxincx's Avatar
i have emailed trixter no response....
Old Jul 12, 2004 | 10:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You may want to try a PM. He will get to you eventually. I am sure he checks his PM's throughout the day.
EDIT: By the way his screen name is Trickster and not trixter. Not sure if maybe you emailed the wrong guy.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
