code 43
Old Jul 15, 2004 | 12:24 AM
Berlinetta's Avatar
code 43
My car gives off a code 43 and i can't figure out why. I replace the knock sensor and ESC module and i still have problems. I noticed though that the knock sensor connector is fairly loose. Sometimes it actually disconnects itself... could this be the problem?
excuse my ignorance...
Old Jul 15, 2004 | 12:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: code 43
The knock sensor is one of the most crucial parts to any FI system. I would find out why the wire keeps falling off.
Old Jul 15, 2004 | 10:13 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Re: code 43
Ditto & double ditto on that.
Old Jul 15, 2004 | 10:51 AM
Berlinetta's Avatar
to put it simply... the knock sensor connector isn't connecting. Its real loose. Even when its attached to the sensor i can wiggle it around. I've been meaning to replace it but have not a clue where i can get the new wiring pigtail.
Old Jul 15, 2004 | 10:59 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to a junkyard and search around.
Old Jul 16, 2004 | 08:42 PM
Berlinetta's Avatar
my question is could that pigtail vibrating around and causing an intermittent connection with the sensor be causing the code 43 to be tripped
Old Jul 16, 2004 | 08:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes!!!!!!!!!!!!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
