1.6 rollers... help any?
Old Jul 24, 2004 | 12:28 PM
NEEDforSPEED's Avatar
l03 POS cam...
"Lift"
intake .351
exhaust .386
with 1.6 rollers rockers that should be something around this .380/412 lift...
well this do anything for me? how much of a diffrents can i see in something like that... in power or what not... how about the computer?
Old Jul 24, 2004 | 12:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The swap is very much so worth it on the peanut cam. I say go for it.
No changes to the ECM are needed.
Old Jul 24, 2004 | 01:08 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
1.6's will be the way to go if u are not lookin to put in a new cam!! Your about right for the lift so I would say go for it to!! But with what you have done so far u should have PROM tuning done!!
Jason
Old Jul 24, 2004 | 02:33 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Re: 1.6 rollers... help any?
Originally posted by NEEDforSPEED
l03 POS cam...
"Lift"
intake .351
exhaust .386
there's an easy way to calculate the difference in lift between 1.5 and 1.6 rockers.
take the lift with 1.5 rockers, divide it by the old rocker arm ratio (1.5), then multiply it by the new rocker arm ratio (1.6)
so, your intake lift would be: .351 / 1.5 * 1.6 = .374
your exhaust lift would be: .386 / 1.5 * 1.6 = .412
duration is not affected. since duration is what affects manifold vacuum, and that is what your map sensor reads, there shouldn't be a major chance in the ecm's tuning. however, the biggest gain you'll see, even with NO mods, is in tuning the ecm. before you do anything else, you should learn to do that.
Old Jul 24, 2004 | 03:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Duration is effected, but then again, it isn't. The actual seat to seat isn't affected. However, there is a change in .050" duration, in a sense. With 1.5 rockers, the valve is open .075" at .050" tappet lift (where the .050" duration is taken). With 1.6 rockers, the valve lift is .080". Therefore, the larger ratio accerates the valve action in a way and simulates slighty larger duations without actaully changing the duration ground into the cam. The lazier the ramp rates, the larger the gains in .050" duration are. With the peanut cam, i would expect about 3-4° increase, so its fairly substantial, in terms of a simple and on part.
Old Jul 24, 2004 | 09:58 PM
will i see anymore HP and TQ from this... about how much more?
Old Jul 24, 2004 | 10:17 PM
25THRSS's Avatar
umm yes, it's a good gain
Old Jul 24, 2004 | 10:34 PM
vjo90RS8's Avatar
Car: 2002 Z28
if u dont want to dump alot of money on roller rockers look at enginekits.com for vortec roller tipped rockers, self aligning for centerbolt heads, only $90. And at sdpc2000.com they sell Federal Mogul stamped steel rocker arms self aligning for centerbolt heads for only $74. I put the federal mogul ones on my car and had a pretty good increase in power. Well worth the money.
Old Jul 25, 2004 | 12:25 AM
well i destop dyno a cam, "LT1"
13.675 in the 1/4 "1.5"
13.654 in the 1/4 "1.6"
thats .021 diffrents
is that about right?
now try to convert that in to HP... what abouts would that be?
Old Jul 25, 2004 | 12:26 AM
25THRSS's Avatar
no
Old Jul 25, 2004 | 12:28 AM
so no ones got hard numbers, or what this well really do other then raz the lift a tad...
Old Jul 25, 2004 | 01:50 AM
vjo90RS8's Avatar
Car: 2002 Z28
i gained 2 tenths and an MPH in the quarter mile. I made a bunch of runs before the 1.6 rockers and my best was a 15.018, after the rockers and going from 6* to 8* advanced timing i went to a best of 14.791.
Old Jul 25, 2004 | 02:09 AM
what mods have you done to run high 14's ...
Old Jul 25, 2004 | 02:26 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
DIFFERENCE!!!
with a C!
Old Jul 25, 2004 | 01:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is only one way to figure out how much improvement any mod will make. That is by strapping it to a dyno and running it down the track. You are going to have to get that through your head.
Old Aug 4, 2004 | 06:29 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Probably about 3-4 HP by itself.
Do full exhaust and you'll get an even better boost too, from the exhaust valve being open a little farther/longer.
Old Aug 7, 2004 | 10:54 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
I just put 1.6 roller rockers on took .5 off the 1/4.
Befor
R/T .223
60’ 2.447
1/8 10.069
Mph 70.78
1000 13.052
¼ 15.553
Mph 90.22
After
R\T .052
60' 2.317
1/8 9.737
MPH 73.71
1000 12.611
1/4 15.033
MPH 93.09
Old Aug 8, 2004 | 12:00 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I was under the impression that most the power came from the 'roller' part of the 1.6 full on rollers.
-chuck
Old Aug 8, 2004 | 02:19 PM
Engine: L03 305 TBI
-chuck
no, the bigger ratio gives you more lift.
Old Aug 9, 2004 | 12:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correct. However, even switching to roller 1.5 RR's can increase power. They are more precise and do not flex like the stockers. The stockers can be anywhere from 1.3x to close to 1.5. They are junk.
Old Aug 9, 2004 | 03:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id skip anything made of aluminum on a street motor. It can fail as aluminum doesnt posess infinite fatigue life (provided the stresses are low enough) like ferrous metals do. I always wanted a good set of pro mags http://www.compcams.com/Technical/Cu...g/HTML/311.asp but Im still to broke to afford them.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
