2 ?'s
Old Aug 3, 2004 | 03:30 PM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
2 ?'s
1st, where is the easiest place to splice into an ignition wire. I just got a tach and it says to splice into a 12v ignition. ust wondered where the easiest place to do it at.
2nd, Which side of my coil is the negative side? remember, 92 TBI (not sure if they are different or not)
Thanks in advance.
Old Aug 3, 2004 | 03:51 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
negative side is the white wires.
Tap into a 12v source from the fues box, that is how i do it.
Old Aug 4, 2004 | 04:24 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
For 12V ignition, gain access to the fuse box and tap into the INST LPS fuse wire (it should be a gray wire). For the tach signal (I'm assuming this is what you are wanting to tap into for your tach), tap into the white wire going from the coil to the wiring harness (FYI, not the white wire going from the coil to the distributor).
Old Aug 5, 2004 | 07:54 AM
Benm109's Avatar
Engine: 305 TBI
Oops, after looking at my post I told you the wrong thing. For 12V ignition, look at the fuse box and use the IGNITION spot. There is no fuse there but that's the best place for a 12V igniton source. Sorry about that.
Old Aug 5, 2004 | 08:03 AM
Car: 89 formula 350
There is no white wire going from my coil to the harness. I have 2 connecters. One connector is gray, with 2 heavy gauge wires(10-12) that are red and white, this run down the back of the engine. The other connector is black that has 2 small gauge wires(14-16) that are also red and white. These are the ones that MSD says to tap into.
I got the 12v source figured out, and I just added an inline fuse to be safe since I used an empty hole on the fuse panel.
Old Aug 5, 2004 | 11:23 AM
Benm109's Avatar
Engine: 305 TBI
Use the white wire from the gray connector. Just to be sure, I am going to go check so I'll confirm this in a minute.
Old Aug 5, 2004 | 11:29 AM
Car: 89 formula 350
Well, majority rules. I have had 4 people tell me it is the wire from the gray connector and the thick white, so that is what I am going to hook it to.
Old Aug 5, 2004 | 11:36 AM
Benm109's Avatar
Engine: 305 TBI
Yep, that's the right wire. I just checked and that's where mine is hooked up to.
