How much to advance timing?
Old Aug 11, 2004 | 01:06 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
I was thinking about advancing the timing on my 305 TBI and then running premium gas. How much should I advance it to get the most performance out of it?
Old Aug 11, 2004 | 01:07 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I ran 4* advaced, with 87octane, and had great success.
Old Aug 12, 2004 | 01:51 PM
Slowmaro91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: 10 bolt posi/3.23
I was wondering the same thing about my car. I have a 305 tbi with a few mods and i really wanted to advance my timing but I'm not sure about how far I can go since I have a stage 2 chip. I know I can still advance it a lil but how much?
Old Aug 12, 2004 | 03:02 PM
Dewey316's Avatar
Car: 1990 Camaro RS
since that is about all stage II chip has, is advanced timing, i don't know that you need anymore.
I tested lots of timing, and 4* gave me the best ET and MPH. I tried everything form 0* to 8*
Old Aug 12, 2004 | 05:04 PM
Car: 91 Camaro RS
I'm not sure how the chips work but from what I've read it'll only advance timing till you hit WOT. Why it's like that I'll never know since WOT is where you really need the advance. Anyway, I just wanted to know if it's safe to advance it any further at all. I run premium gas and have a few other things done if it matters at all. Thanks again for any input.
Old Aug 12, 2004 | 05:15 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I thought the ECM overides the timing and makes its own adjustements?
Old Aug 12, 2004 | 05:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It adds to whatever you set the base at. If it detects knock it pulls timing.
Old Aug 13, 2004 | 12:27 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
The best way is to set the timing to stock and do all that on the chip. Some places like more timing than others, and if u advance the base timing to x*, the whole table is set that high, even if its too much or not enough.
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
