TBI crappy idle
Old Aug 14, 2004 | 07:47 PM
CarAteMyMoney's Avatar
TBI crappy idle
Just got a '91 Formula L03
Idles pretty rough but once you break the idle it's really smooth
Anyone have any ideas as to how to fix this?
Old Aug 14, 2004 | 09:45 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
- clean your idle-air-control-valve (IAC)
- replace your spark plugs and wires, distributor cap and rotor
- get a new air filter and fuel filter
- replace your oxygen sensor
- try misting some water into your throttle blades to clean out the carbon in the combustion chambers
does it idle better when the engine is warm or cold?
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: TBI crappy idle
Check the EGR as well. Common symptom for a valve thats stuck open.
Old Aug 14, 2004 | 10:26 PM
Re: Re: TBI crappy idle
How do I check that valve?
I also got a code 32 before but it went away
Old Aug 15, 2004 | 12:14 AM
Car: 88 Camaro SC
Engine: SFI'd 350
You could pull the valve and visually inspect the pintle. If its stuck open then youve found your problem. Not a bad idea to clean all the carbon deposits out as well. After youve pulled it to check the valve, you can also move the diaphram by hand to make sure it still moves freely. Only some of the egr valves can be checked with vacuum. IIRC the negative back pressure and standard types can be checked with a vacuum pump to see if they are functioning.
Old Aug 15, 2004 | 06:09 AM
joshwilson3's Avatar
Old Aug 15, 2004 | 02:09 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Yeah... Underneath there is a diaphram inside the sheetmetal housing. It should move when you push it up with your fingers.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
J.C. Denton
Aug 31, 2015 03:11 AM
92camaroJoe
Aug 13, 2015 06:07 AM
