I started to have an ideling problem again!
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Well the car runs ok when driving normall , but when at idel not really good. The car stays at one rpm but feels like if the car is a little camed out. But when i put on the a/c It feels like if i have a 300 duration cam (excadurating). When i play around with the pcv hose i can hear the idle go up and down, maybe about 100 rpms or so not too much i think it is the pcv valve can be bad becouse: At my buddys house the other day we were doing something to his car and for some reson i got board and pulled of the pcv valve from the gourment of the valve covers, And heard a tikking sound. I think thats normal?????? Well mine is just there doesent do anything No tikking, the little valve in side doesnt move (nothing). And the pcv valve is about 5 months old, the hose was used before and then put on my car. What should i do? I think tomarow im going to change the pcv valve/hose. Only about $5.00 right?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
PCV vales are super cheap and they should rattle when shaken. You could have a million other things causing a rough idle though.
What is the state of tune of the car.
Plugs
Wires
Cap
02
etc...
Plugs
Wires
Cap
02
etc...
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
check for vacume leaks especialy where the PVC connects to the TB.
Car: 1990 Camaro RS
I posted that at 5:30 AM. I am having a very bad spelling day.
In an e-mail at work, I told some empolyee's to "apologies for any incontinence this has caused."
Engine: 5.7 tbi
Transmission: t5
Well i guess (shifty) You dont remember the mission i was on before. I changed the spark wires, spark plugs, fuel pump , fuel filter, i cleaned the crap out of the iac, new o2 every thing i would have had to change i have done it.
Car: '90 RS
Engine: 377 LSX
Engine: 5.7 tbi
Transmission: t5
Well i found the victum, it was the vacume the has the one way valve in back of the manifold that goes to the air conditioner. That hose has the biggest crack. Got it fixed and the car is working like a champ. Thanks alot shiftycapone, you are a really good help on the site.
Car: 1990 Camaro RS
ohhh burned.
i suggested the vacuum leak
Just Kidding, glad you got it going.
Just Kidding, glad you got it going. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
92camaroJoe
Aug 13, 2015 06:07 AM
