i need help from everyone with an lt1 cam
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
well guy i have posted couple of times of a problem i have i have lower my fp and that help a bit with saving gas but didnt fix the problem i also adjusted my vavles and that did help a lil but im going to explaing wat my cars does and tell me wat u think it is?
okay lets say u hold the brake and give it gas to like 1500 stall in drive and u let off the brake and punch it like takes a moment to get rpms like it bog to like 2600 rpms wat can this be?
now lets say im driving normal when i give it a lil gas it runs fine but out of nowere it feels like boop boop exc. wat can this be?
when i have the a/c on is like wants to turn off like it misses or chokes i dont know but i have to put the car in nuetral.wat can this be?
also wats the best fp for a lt1 cam tbi motor at idle in drive?and wat a good base timing ?remember i do have a chip burn for the lt1 cam and my mods
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
your never going to get it with just FP adjustments. I NEEDS TO BE TUNED.
the bad idle is probabaly due to a combination of too much fuel, and not enough timing. the bog at cruise is problably to much timing there, and not enough fuel, the "boop boop" i can only assume is not enough pump shot of throttle tip in.
Are you going to keep asking the same question, or are you finally going to listen to some of us one of these days.
Car: White KSwisses
Engine: 5.3L Gen III
Im trying to understand the effects of AE. It confuses me.
Car: 1990 Camaro RS
too much will bog, too little will be lean, and bog and/or backfire.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 89 Camaro RS
Engine: 5.0 tbi
OKAY ,BUT I HAVE GOTTEN 2 CHIPS ALREADY FROM TBICHIPS BURN FOR THE LT1 CAM AND NO RESULTS. I HAVE TRY TO LOWER MY FP AND ADJUSTED MY VAVLES BUT NO RESULTS. IM BUYING THE WINALDL CABLE THIS WEEK SO LIKE IN 10 DAYS I WILL USE THE WINALDL PROGRAM AND SEND ALL INFO TO TBICHIPS AND THEN HE SHOULD KNOW WATS WRONG WITH MY CAR. SOUND GOOD.MY BASE TIMING WITH THE CHIP IS 4* SHOULD I PUT IT HIGHER OR LOWER?
Car: 1990 Camaro RS
Caps lock is just to the left of the 'A' button.
Data logging is that is going to tell you what is wrong. changing the base timing, and fuel pressure will not cure this. Personaly i suggest you give tbichips the big middle finger, don't waste any more money with him. Buy the equipment and do this yourself.
Car: 89 Camaro RS
Engine: 5.0 tbi
HE DOESNT CHARGE ME NOTHING,BUT BUYING ALL THE NEEDED GEAR IS LIKE 250 DOLLARS AND I DONT HAVE THAT RIGHT NOW. ALSO WERE DO U BUY THE BLANK CHIPS FROM?AND HOW DO U PROGRAM IT?IS THE SOFTWARE LIKE A HYPERTECH THAT U PUNCH IN YES OR NO AND SPECS #?
Car: '90 RS
Engine: 377 LSX
There is a section on chip burning in the sticky at the top. Also spend some time reading in the DIY PROM board. There is a learning curve involved when burning your own chips. It takes many many burns to get a chip just right.
Car: 1990 Camaro RS
Dataloging : http://winaldl.joby.se/
Tuning : https://www.thirdgen.org/techbb2/sho...hreadid=245398
Sticky : https://www.thirdgen.org/techbb2/sho...hreadid=227281
Car: 1990 Camaro RS
yeah ronny, we know what caugh caugh and gurgle gurgle are, its hard to explain that to someone who hasn't experianced it.
Aren't you glad you learned tuning, so you can use highly technical terms like, gargle.
New2Chevy
Sep 28, 2015 12:35 AM
