Fuel Pump ?
Old Aug 29, 2004 | 11:17 PM
1bad92TA's Avatar
Car: 1992 Pontiac Firebird
Engine: Lo3 305
Transmission: th700-r4
Axle/Gears: stockers
Fuel Pump ?
Up to what horsepower will the stock fuel pump hold on a LO3 engine. i.e. would i need to install inline/intake pump if i put an intake on?
Old Aug 30, 2004 | 02:12 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Not sure if I follow but the stock pump will be fine for most bolt on mods. It doesnt supply much pressure or flow so if your making mods that require lots of extra fuel over whats available stock then the tbi pump has to go.
Old Aug 30, 2004 | 05:43 PM
1bad92TA's Avatar
Engine: Lo3 305
OK
I was wondering if there is a replacement, in tank pump, that i could find and that i could install now before i make any major mods that won't mess with my stock set up. I'm planning on putting an intake on and an after market throttle body
Old Aug 30, 2004 | 05:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: OK
You can replace your pump with any 3rd gen high flow or multi port pump. Your fuel regulator will keep the pressure where it needs to be and will divert all excess fuel into the return line. Your stock pump is fine until you have a nice set of heads and cam (some are still even fine with this).
Old Aug 31, 2004 | 11:45 AM
BigBadJap's Avatar
Car: 1989 GMC Jimmy Fullsize
Engine: 5.7L TBI (LO5)
Do TPI pumps fit as higher PSI direct replacements for the TBI pumps?
- electrical connectors
- dimensions
- fittings
- volume
My TBI pump is on its last legs and I need a replacement pretty soon.
Old Aug 31, 2004 | 11:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
TPI pump is a direct replacement.
Old Aug 31, 2004 | 12:07 PM
BigBadJap's Avatar
Thanks!
I can order ACDELCO EP241, TPI Fuel pump for $131 CDN, or I can order Edelbrock 3581 ( I think this will fit ) mpfi fuel pump for $180 CDN. Hard to find walbro pumps here.
I'd like a pump that'll flow enough for about 300HP.
What do you recommend?
Old Aug 31, 2004 | 12:32 PM
Dewey316's Avatar
Car: 1990 Camaro RS
There is a company from canada that makes a VERY nice walboro kit, i'll try to find you a link.
Old Aug 31, 2004 | 02:23 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
get the walbro
I love mine
serously though get a good one you only want to pull that tank once
ryan
Old Aug 31, 2004 | 02:41 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
ive doen the walbro 190 pump swap.. its really a nice pump... got it for around 90 dollers from a site. .. ill have to see if i cand find it for ya
Old Aug 31, 2004 | 02:44 PM
bbtaz97's Avatar
Car: 91 RS
here ya go
http://www.autoperformanceengineering.com/
Vehicle 190 lph HP
'85-'92 GM Universal
FPG001 - $83
a.k.a. GCA701
255 lph
N/A FPG002 - $93
a.k.a. GCA722
255 lph
FPG003 - $108
a.k.a. GCA758
Old Aug 31, 2004 | 03:17 PM
rad8tion's Avatar
Engine: RAMJET 350
yeah got mine from there as well, good price, everything I needed was in the kit and fast shipping
ryan
Old Aug 31, 2004 | 04:32 PM
BigBadJap's Avatar
Thanks for your help. My daily driver is quickly getting worse. I've decided to go with the Edelbrock 3581 as I can have it tomorrow, so I can make the swap this weekend.
I sure hope I've ordered the right thing.
http://store.summitracing.com/defaul...h&Ntt=edl-3581
Old Aug 31, 2004 | 04:46 PM
rad8tion's Avatar
Engine: RAMJET 350
that doesn't come with a tank gasket or a hookup hose does it?
Old Aug 31, 2004 | 05:04 PM
BigBadJap's Avatar
Hmmm. I think it's just the pump, filter, and harness.
I suppose I should replace those while I'm at it!
Does the hookup hose usually have to be replaced?
Old Sep 1, 2004 | 06:13 AM
rad8tion's Avatar
Engine: RAMJET 350
the one that was origionaly on mine looked rather weak, and the walbro kit had a new one with nice clamps so I replaced it
ryan
Old Sep 3, 2004 | 02:24 PM
BigBadJap's Avatar
FYI. I got my Edelbrock 3581 pump, and it is infact a Walbro Pump. It's a GSS340, 255LPH hi-pressure.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
