LT1 cam part number?
Old 08-30-2004, 09:54 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
I bought a used LT1 cam from a guy recently. It's supposed to be from a 95 Trans Am. The part number stamped on the cam is gmpt-bc-17-242. Before I put this in my 305 L03 I want to make sure its actually an LT1 cam.
Does anyone know if this is the right part number for an LT1 cam?
Old 08-30-2004, 10:30 PM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would measure the specs and then compaire then to the published GM numbers.
Old 08-31-2004, 09:32 PM
91RockS's Avatar
Car: 91 Camaro RS
Sounds good, but I don't have the equipment to take these kinds of measurements. I was hoping someone on this board would be able to verify the part number. I seached and found a post by Token with this same cam part number, but his was supposed to be from an LT4, not an LT1.
Old 08-31-2004, 10:18 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I have a LT1 cam from a 94 TA in my room right now and the only numbers that are on mine are...
...241.cpc.bc. cpc.bc.1
1992 Trans Am
05-10-2023 07:19 PM
355sbcTPI
08-19-2015 04:38 PM
TA8487
08-16-2015 12:21 PM
sreZ28
08-14-2015 07:48 PM
armybyrd
08-10-2015 09:23 PM
Quick Reply: LT1 cam part number?
