when setting timing...
Old Aug 31, 2004 | 04:13 PM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
which mark is zero. Im running nitrous and i want to be FOR SURE. Right now i think the guy before me said it was a 6* advanced. Any help would greatly be appreciated. I could not find the tech artical.
Old Aug 31, 2004 | 04:55 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Try to get some sand paper on the timing tab and clean it off. There are numbers on it. This is a blury pic but if you clean yours off it is easily read. There are links on setting your timing in the sticky up top.
Old Sep 1, 2004 | 12:17 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Do what shifty said, but 0* should be at the indent of the largest "V" farthest to the right (if facing the engine). Right in the middle of that "V"...hope that makes sense for you!
Old Sep 1, 2004 | 06:01 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Here, this should make it easier.
Old Sep 1, 2004 | 07:06 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
someone made this for me once.
Old Sep 1, 2004 | 08:32 AM
89305RS's Avatar
Thanks guys it did have the numbers. All i did was spray it down with carb cleaner and blew it off with air. Thanks again. The nitrous runs were pretty good. I only did it on the street though. Check for my new post on my nitrous run problems. in the power adder section.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
