using the tbi distrib for carb swap????
Old Sep 5, 2004 | 07:33 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Just wondering if i can run the tbi distrib if i do a carb swap to hold me over until i can pick up an msd pro-billet... I heard somewhere i can just @ full-throttle i wont have any advance.. let me know guys
Old Sep 5, 2004 | 08:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You'll still get advance only it will all come in at once and you get 20deg over what you set it too at idle. It's actually a pretty good setup for the guys who want to lock out the spark advance on harry race motors.
Old Sep 5, 2004 | 08:42 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
uhm you can use it just fine, just leave your ecm in and map sensor connected. You will of course have to burn chips to get a better spark curve than the stock one. I ran a carb on my setup with the 7747 ecm running spark for 2 years
Old Sep 5, 2004 | 08:52 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
really. so it will idle fine and junk??? pablo do u think u could burn me a chip? im running an edelbrock 600cfm carb all choke junk removed... im junk concerned about idle quality and stuff like that, if u guys say it will run, then im going to go forth with the swap
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
tero
Aug 15, 2015 02:47 PM
cstrobel65
Aug 15, 2015 10:19 AM
tero
Aug 6, 2015 06:34 PM
