Who has a single plane intake?
Old Sep 8, 2004 | 02:18 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Just looking for some feedback, I picked one up and I have people telling me left and right I'm gonna lose my low end. I thought single planes and fuel injection worked well together. So I want some thoughts from people who actually are running them.
Old Sep 8, 2004 | 04:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dewey is one of the single plain pioneers. He did not lose any low end with his single plane swap. Well none that his butt dyno could feel. I am sure he will shed his knowledge on this subject.
Old Sep 8, 2004 | 04:30 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yes i have one.
I didn't notice any loss of power, and the throttle response is AMAZING. I'm very glad I went this route. THIS is an old thread in which DanW brought the single plane idea up again. Since TBI is not dependent on the vacume pulses to fuel, like carbs are. A single plane does not suffer the low RPM fueling issues that a carb does. I did not put this intake on a stock motor, so I cannot comment on how its performace is there. But with my cammed 305 (206/216 .447 .447 112), it fits like a glove.
Old Sep 8, 2004 | 07:55 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Pablo is also running one.
I switched from an RPM AirGap to the Holley Street Dominator single plane. Keep in mind that the AirGap is supposedly the cream of the crop in dual planes.
If anything, my low end response is better with the single plane. Also, I moved so much more air up top that I had to retune.
Old Sep 8, 2004 | 08:29 PM
Car: 1990 Formula
Pablo is running the same intake I just bought, while his times are extremely impressive I failed to ask how it affected his low end power. Its a good thing you TBI gurus are around :hail:
Old Sep 11, 2004 | 06:19 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
with the carb the low end is kind of lazy but who races at 2000 rpm? the times speak for themselves as far as how the performance is.
With TBI on there the low end is great, youd never know there was a single plane under the hood with the way it responds.
Most (and i do mean most) of the torque loss associated with single planes is because there is reduced vacuum signal at the carburetor. No vacuum signal needed with TBI.
Old Sep 15, 2004 | 07:29 PM
DM91RS's Avatar
Car: 91 RS
Got lucky the first time I checked e-bay.
Old Sep 15, 2004 | 09:38 PM
steve8586iroc's Avatar
DM, what are you putting it on. I hope it's not the car in your sig.
Steve
Old Sep 16, 2004 | 06:29 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
sweet lloking 7525. what did you give for it?
Old Sep 16, 2004 | 03:19 PM
DM91RS's Avatar
Car: 91 RS
Steve
The Vortec's are going to be removed, reworked and installed on a 350. I have a set of TPI 305 heads that I've ported that will go with the 7525. How, when and what order I'll do all this I don't know.
I have an S10 that I need to get repaired (or replaced) after being totaled that will probably get the left over motor. I have two 350 shortblocks so the TPI heads and 7525 might go on one of those. ? Don't know right now
Old Sep 16, 2004 | 03:23 PM
DM91RS's Avatar
Car: 91 RS
Buck fifty......the last file that I saved from SummitRacing the intake was unavailable but it quoted that the price was then $165 so I thought that this was a decent deal for a new unit.
Old Sep 16, 2004 | 03:29 PM
DM91RS's Avatar
Car: 91 RS
Old Sep 16, 2004 | 11:11 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I am using weind 7547 I love it ... here are some before and after pics :hail:
Old Sep 16, 2004 | 11:12 PM
MY-92-RS's Avatar
before
Old Sep 16, 2004 | 11:13 PM
MY-92-RS's Avatar
after !!
Old Sep 24, 2004 | 09:16 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
So, do you think the single-plane Vic. Jr will work on my 92 TBI? or would the stock intake be better? Just curious, even though the Vic Jr is a High RPM intake, Im just wondering, cause if will work, then Ill bolt it on in a heartbeat.
Bubbajones_ya
Jul 6, 2024 08:32 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ericjon262
Sep 11, 2015 06:07 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
