Is anybody running......
Old Sep 20, 2004 | 11:34 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Is anybody running an Edelbrock Performer TBI with 416 heads. I would like to see a picture of the 4 center bolt holes on the manifold. They will have to be ovaled and there is not much material there to begin with.
Also...
If I removed all material on the out side of the bolt hole and made it into a U-shape, do you think I will have problems with air leaks? Keep in mind with this set up and the angle the center bolts go in at, the outside of the bolt holes do not receive direct downforce pressure from the bolts anyway.
Opinions wanted.
Thanks.
Old Sep 21, 2004 | 01:27 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I did this with a performer rpm intake with no problems. I did make some wedge shaped washers out of some pipe so that helped too. I did not have to cut clear through but I have seen some guys do it that way with no problems.
Old Sep 21, 2004 | 05:29 PM
azvolfan's Avatar
Wedge shaped washers out of some pipe. Hmmm. Good idea. Thanks Monte.
Old Sep 22, 2004 | 05:28 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Problems already? Poo, let me know how it goes!
Old Sep 22, 2004 | 07:52 PM
azvolfan's Avatar
No, no problems. Just wondering about the center bolt holes.
