Cam Setup Question
Old Sep 28, 2004 | 10:43 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Cam Setup Question
Hi, i have a 89 RS 5 spd, with a 95 pickup 350 in it (L05), it has the flat lifters, I was talking to the guy from TBIChips.com and he suggested this cam from Summit:
http://store.summitracing.com/defaul...1104&x=11&y=10
Now would this cam be ok and what kind of performance increase would I see, thanks alot guys!
Old Sep 28, 2004 | 11:13 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You won't see much of a power increase if you do not get into chip work. TBIchips is a good place to get started and to get your car running. If you want to make the most power and get the most for your money you will have to burn your own. What heads are you running pon that LO5. You may want to think of upgrading those as well.
Old Sep 28, 2004 | 12:15 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Isnt that engine you have installed a roller block?
If it is, i wouldnt go with a flat tappet setup.
Actually even if it wasnt a roller block, i would go with a retrofit kit and then a roller cam.
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
