holley projection manifold install tips.
Old Oct 15, 2004 | 10:38 AM
Ronny's Avatar
should be recd by me monday. i plan on replacing the throttle cable as it is most likely worn(101,000 mi.). i have vette. i will assume it is different as it is a crossfire TB cable. would an F body be the choice? the GM TB 7.4L is a truck application 1995 model year. is a truck cable a better idea? do you think the bracket will line up - Holley to GM.? also i have no kick down as a manual trans. will the cruise control be an issue? would hate to replace that unless realatively low cost? any experience with this out there?
Old Oct 16, 2004 | 02:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Ronny,
When i put the wieand manifold on. I had to modify the bracket for the throttle cable. Basicly i had to cut one 'leg' off, so it would be the correct diffrence from where the throttle body sits.
Old Oct 18, 2004 | 09:13 AM
Ronny's Avatar
thanks.
Old Oct 18, 2004 | 02:19 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey Ronny. With mine i had to extend the throttle bracket too just like that. Then I had to relocate the coil because the bolt holes on the Holley manifold aren't stock spacing so it won't bolt up. I also have to run an EGR block-off plate because the stock size valve hits the plenum (don't know how a corvette is though). anddd I'm drawing a blank on any other stuff I had to do, but ask some questions if you have them. All in all it wasn't a bad install.
Frozer!!!
Jan 19, 2024 04:55 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
