Anyone know what this hose is?
Old Nov 8, 2004 | 04:42 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
This hose has been hanging there every since i bought the car almost 2 years ago. Anyone know what it is or where it plugs in to? Is it a hazzard being unplugged?
Here it is:
Old Nov 8, 2004 | 04:50 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
It hooks up to your air cleaner assembly. I think it operates the butterfly in the assembly intake. I think it's a thermac. I could be wrong on that name though.
Old Nov 8, 2004 | 04:52 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, well that makes since, i dont have the stock assembly, i have open element so i guess ill just continue to ignore it
Old Nov 8, 2004 | 05:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is for the thermac in the stock air cleaner snorkel. I would just cap it and get rid of that piece of hose. I think there is a pic that labels the vacuum ports in the new to TBI sticky above.
Old Nov 8, 2004 | 08:37 PM
azvolfan's Avatar
Yeah, if your running an open element you should just plug it. Leaving it open will make your car run crappy.
Old Nov 9, 2004 | 04:38 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Where do you get the plugs for this? Mine still looks like the attached pic.
Old Nov 9, 2004 | 04:40 PM
25THRSS's Avatar
Just go to any auto parts store and you'll find the plug. I can't remember the exact size right now, but I'm sure someone else does. What size is the stock hose you have on there now?
Old Nov 9, 2004 | 04:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can get a set for a few bucks in the "help" section at autozone. You can use one of 3 of the 6 or so they give you in the pack. Just look for vacuum caps. It will slide over the port and you are set to go.
Old Nov 9, 2004 | 04:58 PM
25THRSS's Avatar
right, but there are many different sizes. Use the same size as the stock hose which is.....
Old Nov 9, 2004 | 05:41 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I don't have the stock hose anymore, but I can confirm that 5/32" works perfectly .
Old Nov 9, 2004 | 05:42 PM
azvolfan's Avatar
I switch back and forth between an open element and a dual snorkel. When I use the open element I just plug it with a screw or something like that.
Old Nov 10, 2004 | 10:44 AM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
mine has a show quality 2" screw stuck in there until I remember to get it capped.
Old Nov 10, 2004 | 10:47 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
As for capping off the stock sized hose...well I used a golf tee....has worked like a charm for years.
D
Old Nov 10, 2004 | 01:00 PM
Cadillac's Avatar
Question: Why do you switch back and forth?
Inspection?
I'm curious if you notice any difference in performance between the two.
Old Nov 10, 2004 | 05:09 PM
azvolfan's Avatar
Inspection is one reason. Another is to see if there is any differenct between the two. And I have not found any. Another reason is the black chromed dual snorkel looks better for a car show or something like that.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
